W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    43 vote(s)
    58.1%
  2. Kawasaki Green
    31 vote(s)
    41.9%
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    [​IMG] Originally Posted by W3STY [​IMG]
    I dont need a Miltek. I do however need to get my 4 pots on the
    I need a Miltek.....
  2. IrishDave
    IrishDave Active Member
    682
    45
    Its hard to explain. If you cut a 45deg edge into one the sides and weld that to the end tank, so in theory you would have a 90deg bend with a tighter radius. Do you see what I am trying to say.
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Bottom line here is that sometimes you have to sacrifice things if you want performance, especially so if you are on a budget of any kind. If cost was no object then you would have a cooler fabricated to the EXACT requirements for you to be able to keep the fogs. But most of the time that's simply not realistic.
    It's the same in all walks of life.
    PCs for example, unless you are willing to spend BIG money, you will not really get good reliability, good performance and small size. That's just how it is. If you are on a budget you have to trade some stuff off against other things.
  4. IrishDave
    682
    45
    Ok looking at your pics I think my idea will/should hopefully work. Well here goes will let you all know the progress.
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    That's it mate. Give it a go and let us know ;)
  6. Westy
    17,443
    1,105
    My main man ScottB5 has recieved the piston seals for my Boxster Calipers. The Calipers are heading to the powder coaters today so should have some nice pics soon ;)
  7. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Westy, I was thinking about your fog lights.
    I'm not sure if you thought about it or its been discussed but can you mod or use the fog light grills/holders from a A4?
    I think they are on the out side of the bumper and away from you pipes.
  8. badger5
    9,603
    2,061
    the problem with the core and what you are trying to achieve is the outlet of the core is not at the bottom of the core, its up a couple of inches.. so does'nt sit in the lower recess like Tufftys/Danes. the outlets can be as large as 63mm allow bends.. but must be right in the sweet spot in the lower recess of the bumper. to get this core to outlet at that position, the bottom of the core will stick out below your bumper.
  9. Westy
    17,443
    1,105
    Hmmm, talk to me.
    I've hacked the cack out of my bumper and there's no longer any brackets/clips so it might be difficult now.
  10. badger5
    9,603
    2,061
    re foglights.. I have seen someone buy the aftermarket fogs mounted on their own brackets, which look very Oe at a glance but are smaller brackets..
  11. Westy
    17,443
    1,105
    That is true. You'd have to cut a slot in the bottom of the bumper to allow it to hang down and then you risk catching it on speed bumps.
    The way mine is fitted means that the bumper goes back on fine with the bottom of the bumper fitting sweetly over the bottom of the core.
  12. ScottD3
    15,165
    1,124
  13. Westy
    17,443
    1,105
    To be honest I'm kind of happy with the way the bumper looks now i've filled in the holes. It sounds like a load of hassle re fitting fog lights when they dont even get used plus I have 2 huge silicone hose poking out the front of my car which kind of blows the stealth aspect out the window ;)
  14. Westy
    17,443
    1,105
    Cheers Scott.
    They're pretty similar to the S3 grills in that the light goes on the outside. When I trimmed my grills as seen in the pic below I used the right grill on the left and left on the right:
  15. ScottD3
    15,165
    1,124
    How well did that work?
  16. Westy
    17,443
    1,105
    You'll see at AITP. It looks quite good to be honest ;)
  17. Westy
    17,443
    1,105
    Fitted a service kit for my 007P DV today. It's 3 years old and never been done. The valve was pretty dirty so I gave it a good clean first then replaced the seals and piston. Not sure if it's made any difference but it's peace of mind really as it's a fairly important valve!
  18. Dani_B19
    9,382
    403
    Benn thinking about your fmic westy, could you not use straight 76mm to 63mm reducers and then use 63mm aluminium 90 bends instead? Would that not keep it tighter but also not be as bulky as the 76mm reducing elbows?
  19. Westy
    17,443
    1,105
    Its impossible to keep the fogs with 76mm pipework mate. If you see mine or Welly's cars at any point you'll understand why ;)
  20. Dani_B19
    9,382
    403
    Even if you did what ive just suggested?
  21. Westy
    17,443
    1,105
    Yep, even if I did what you say ;)
    The core only just fits in the gap between the radiator and the bumper so the end tanks bulge out too much to have the pipework in the lower bumper recess. Therefore you have to have the pipework poking out the fog holes. Even with my direct 90 degree bends it wasn't enough to clear the fog light brackets.
  22. Westy
    17,443
    1,105
    Ok tonight I fitted the jetex heatshield that Tam made for me. Wicked looking heatshield and it fits as tight as a flee's back doors!
    Anyway as usual, here's some pics ;)
    Heatshield and 80mm 90 degree silicone:
    Jetex and MAF out the way:
    Notice how clean my TIP is without venting oil and sh!te back into it:
    Heatshield and MAF in place:
    New silicone hose trimmed to fit:
    Jetex back in:
    Complete with engine and battery cover back on:
    This is the penultimate thing on my car for the moment :( Just got to fit my Brembo calipers and I'm done :whistle2:
    Inertiauk likes this.
  23. Prawn
    11,677
    3,677
    Looks awesome dude :D
    really like how OEM the jetex looks with the heat shielf in place too. Top job.
    Does Tam make these often? I might be after one to suit my ko4/B5 TIP setup later in the year.....
  24. Dani_B19
    9,382
    403
    Looking nice mate.
    Neil have you changed the gear cable ends to the circlip ones or have yours always been like that?
  25. Westy
    17,443
    1,105
    He's only made 2 to date, one for me and one for himself. He made mine as a birthday present but he may make more for cash, drop him a PM.
    They've always been like that mate.
  26. LiveWire
    LiveWire S3X
    329
    Out of interest what material is your heat shield made from? Its just I am using one made from alliminium, after just a short drive the heatshield gets so hot I dont think it does anything in the way of shielding heat away from the Jetex!!
  27. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Nice one dudeson that looks very smart!
  28. Westy
    17,443
    1,105
    I'm not sure but I think it's thin steel painted matt black. Tam's one has been on his car for a while now and it seems ok. Im also hoping that my cold air feed will come into play a bit more now too.
  29. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,824
    10,928
    Looking excellent w3sty
  30. Piester
    Piester Member
    90
    They aren't very hard to make if you can be *****...
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/114025-diy-heat-shield-under-%A320.html?
    I used steel instead of aluminium which is doesn't heat up too much. Will obviously be much better once I've got a FMIC so that I can pipe a cold air feed in.
    Still need to spray mine, black looks so much better!
  31. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ALuminium is superior against heat than steel, why do you think alu is used for amp heatsinks...
  32. Westy
    17,443
    1,105
    Scotty has just sent me this pic after collecting the calipers:
  33. s3dave
    10,110
    736
    Look great, has he powder coated the threads though?
  34. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    Gay
  35. Westy
    17,443
    1,105
    What threads? Scott didn't powder coat them he dropped them off to a powder coaters near him. They've done calipers before so I'd like to think that they masked off all the important bits!
  36. s3dave
    10,110
    736
    Lol just asking...:)
  37. Sam_
    Sam_ Down under
    3,038
    480
    I have to agree with superkarl here. Red is a bit **** no? I am all for black and OEM+, especially here when the old bill are really hot on any mods.
    Disclaimer, I might have been for a few beers
  38. Westy
    17,443
    1,105
    Scott said they need a bit of cleaning up as there are some shot balls inside that will require washing out. He's in charge of cleaning them and refitting the pistons with the new dust boots and seals so fingers crossed everything is fine. They're going to be like brand new calipers.
    I ordered braided hoses, Motul RBF660, and ferodo DS3000s from Bill this morning.
  39. superkarl
    9,612
    2,481
    Haha. Im just jealous, itl look really good, fresh!
  40. Sam_
    Sam_ Down under
    3,038
    480
    Now you made me feel bad haha.
    Regardless of colour, I'm sure they'll work awesome ;)
