VW polo problem ......ideas please
205man Jan 17, 2010
  1. 205man
    205man Active Member
    1,072
    14
    my friends vw polo has developed an annoying problem, but with the weather being rubbish and me working ive not had chance to look but though id ask for possible ideas here before i get chance.
    its a 97 1 ltr polo in showroom condition she has it regular serviced and is well looked after, but has developed the folowing problem
    cuts out randomly whilst driving and did it once at 30mph, but when you stop car restarts straight away and may not play up again.
    cuts out when slowing down/coming to a stop, even with clutch pedal fully down, again restarts first time and you can carry one and may not do it again.
    engine revs sometimes all over the place going up and down
    any help/ideas would be much appricated as it hard to find a fault thats not there all the time.
    alan
  2. ian bleakley
    ian bleakley New Member
    hi, sounds like the idle control valve you will have to take it to your local garage because you need to plug in to the diagnostics hope this helps
  3. Mister D
    Mister D New Member
    the throttle body needs cleaned very common problem
  4. Broken Byzan
    13,237
    466
    Last time i had one of these to fault find it was the crank sensor throwuing the code and causing the cut outs. Have you had it on vagcom?
