VW Polo Fault codes
simfin Feb 18, 2011
  1. simfin
    simfin New Member VCDS Map User
    13
    Had my Sons Polo looked at by a very kind garage that used a VCDS to check the codes. Below is the result - 3 intermittants and a normal one. The codes have been cleared which has cleared the Orange engine warning light and has stayed off for 10 miles driving back.
    I know it is not an Audi, but does anyone have any clues what may have been the problem - specifically the non-intermittant code 16804. It is a 1.2 E '52 plate
  2. hades-
    9,481
    646
    im gona go for 02 sensor or cat
    16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
    Possible Causes
    • Leakage in Intake and/or Exhaust System
    • Catalyst faulty
    • Oxygen Sensor(s) faulty
    • Oxygen Sensor(s) Control faulty
    Possible Solutions
    • Check Intake and Exhaust System for Leaks
    • Check Catalyst
    • Check Oxygen Sensor(s)
    • Check Oxygen Sensor(s) Control
      • Perform Oxygen Sensor(s) Aging Check
  3. hades-
    9,481
    646
    your 16556 will go with the 16804 code
  4. simfin
    13
    Excellent, thanks for the info - Hope it isnt the Cat :(
    Where do I find the cross referance for the fault codes? Is it freely available ?
  5. simfin
    13
    Ahhh, dont worry , found it on ross tech. thanks again
  6. NHN
    29,510
    1,764
    Yeah I'd also go with O2 sensor 1st.
