VW Lupo Airbag Delete/Disable?
Boon Oct 25, 2012
  1. Boon
    Boon Active Member
    441
    59
    Hi all!
    My mate has just bought a VW Lupo and the steering wheel has been changed and thus left the airbag light on...
    I have tried to disable it with VCDS but still comes up with the faults and the light on the dash
    Is there any way to disable the lot? Soft coding maybe?
    Log as follows
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Thursday,25,October,2012,19:49:25:41744
    Chassis Type: 6X - VW Lupo
    Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
    VIN: WVWZZZ6EZ1W009670 Mileage: 176470km/109653miles
    Address 01: Engine Labels: 036-906-033-AVY.lbl
    Part No: 036 906 033
    Component: 1.6l/4V SIMOS3 00HS3551
    Coding: 00031
    Shop #: WSC 01286
    VCID: CE99DED30A74B568639
    WVWZZZ6EZ1W009670 VWZ1Z0A1480537
    No fault code found.
    Readiness: 1110 1101
    Address 03: ABS Brakes Labels: 6X0-907-379.lbl
    Part No: 6X0 907 379 C
    Component: ABS/EDS 30 IE CAN V004
    Coding: 15603
    Shop #: WSC 01286
    VCID: 448D7CFB5438CF3845D
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6E0 909 605
    Component: 02 AIRBAG VW5 0005
    Coding: 12338
    Shop #: WSC 01286
    VCID: E8D5084B88D04B58095
    3 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    32-10 - Resistance too High - Intermittent
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    01281 - Airbag; Drivers Side; Disabled
    35-00 - -
    Address 17: Instruments Labels: 6X0-920-xxx-17.lbl
    Part No: 6E0 920 900
    Component: KOMBIINSTRUMENT BOO V07
    Coding: 00440
    Shop #: WSC 00650
    VCID: DFC713975D9E0CE0F8F
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN
    Coding: 00022
    Shop #: WSC 00000
    VCID: F0E5602BB0008398515
    Address 25: Immobilizer Labels: 6X0-953-257.lbl
    Part No: 6X0 953 257
    Component: IMMO 0008
    Coding: 00001
    Shop #: WSC 00617
    VCID: FDFB491FF752FEF0CA3
    Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
    Part No: 1C0 962 258 N
    Component: 1X Zentr.Verriegel. 0001
    Coding: 00257
    Shop #: WSC 01286
    VCID: 32612A23FE8C7188E71
    Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
    Part No: 6N0 951 171 C
    Component: Innenraumueberw. 0003
    VCID: 2F672357EDBE5C6088F
    Address 55: Xenon Range Labels: 6N0-907-503.lbl
    Part No: 6N0 907 503
    Component: Leuchtweiteregelung 0002
    Coding: 00001
    Shop #: WSC 00000
    VCID: ECDD745B9C2867786DD
    End ---------------------------------------------------------------------
    He needs to get it through a MOT!
    Any ideas would be great
  2. Boon
    Boon Active Member
    441
    59
    Sorry, steering wheel changed to a Sparco iirc sports wheel with NO Airbag!
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Easiest way is to fit the proper steering wheel in the car.
  4. gen.heinz guderian
    1,346
    126
  5. Boon
    Boon Active Member
    441
    59
    Very true, however he doesn't have the original wheel
    After some digging it seems that the control module has been scanned by an inappropriate scanner and rendered it useless
    Looks like an expensive fix, I just thought there my be a way to remove the module and decode the rest with VCDS to turn all of the airbag system off?
