Vredestein - bargain
Macdoon Jan 3, 2013
  1. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,997
    758
  2. g00se
    g00se Active Member
    268
    26
  3. rezulteo
    rezulteo Site Sponsor Site Sponsor
    233
    15
    Let us know how you find them!
  4. Macdoon
    1,997
    758
    I'm going from Toyo proxes, which have been awesome wet & dry, my mate has the vredestein on his A4 and he says they are awesome, so time will tell
  5. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,053
    69
    It's difficult to find the limits of grip with quattro in the dry with anything other than cheap budget tyres (on normal roads), but I've never felt so confident in the wet than with the Vredesteins. They cut through surface water like a hot knife through butter!
  6. hades-
    9,481
    646
    iv been useing vreds for a few year never had a problem with them
  7. dieseldoug
    dieseldoug Member
    240
    53
    I use the Vredestein's here in Aberdeenshire, great tyres and never had any issues with them, best traction ever.
  8. Dazmo
    Dazmo Active Member
    1,762
    Pretty good, although does not beat my ebay bargain of 4 x vredestein ultra sessantas with 7mm tread and in perfect condition for £240 cash!
    I ripped the guys arms and legs off for those!
  9. Macdoon
    1,997
    758
    Definate bargain that fella
  10. Macdoon
    1,997
    758
    Ok so 2 weeks in, found the tyres sqeeled a bit on cornering, so upped the psi to 36 from my usual 33 on toyos, that made all the difference. As for performance, they are pretty awesome in the dry - definately on par with if not slightly better than the toyos. In the wet - f**k me they hold and repel the water, much better than my trusted Toyos :arco:
  11. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    I think thats about the ball park figure I paid for the exact same tyres. Been on a year now and performing well. Got mine from Blackcircles.com
  12. Joe_Murphy21187
    1,053
    69
    36psi... I run 40 - 42psi...
    This is based on the standard pressures from 18" rims/tyres
    Glad you're as impressed as everyone else with the Vreds!
  13. Macdoon
    1,997
    758
    JJ think i'll up the psi again and see what the difference is, yep i'm thinking they will be a keeper, snow is a coming so i'll see how they fair
  14. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    40-42psi is quite high isn't it?
  15. Wrath
    Wrath Well-Known Member
    1,196
    41
    Yep, really high!
  16. razza1
    razza1 Well-Known Member
    3,063
    820
    Really high...
  17. rowdyboy
    rowdyboy Member
    804
    19
    42psi is standard pressure on the 3.0tdi. Don't you check your handbook or pressure sticker???? Anything less and you can tell the difference in handling.
    You go to 46psi if the cars fully loaded.
    Vredesteins are amazing, I got 4 fitted for £490 from tyreman.co.uk
  18. Wrath
    1,196
    41
    Wonder why the psi is so markedly different between the 2.0 and the 3.0. Presume heavier engine.
  19. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Better put mine up from 37 then! :keule:You running 42 all round then? I've changed my wheels from 235/40/18 to 255/35/19 btw.
  20. rowdyboy
    rowdyboy Member
    804
    19
    Yeah, 42 psi all round.
    Im not sure how it works with your different sized wheels.
  21. razza1
    3,063
    820
    Must be then
