votex rear skirt help!!!
khalil Mar 20, 2008
  1. khalil
    khalil Member
    774
    can some tell me if you need to remove the original rear skirt before you can put on the votex one or does it just glue over the orignal one??? also is there screws, brakets to stick it on?? also to today i got my votex front spoiler i believe its a glue on thing but there is few holes for screws does it has to get screwed on too??
  2. khalil
    khalil Member
    774
    any help pls
  3. Boydie
    Boydie Guest
    What year is your car? By the sounds of your description you may already have the sline rear splitter :S
    The front bonds onto the front bumper along with two screw brackets under neath - I didnt get these with mine as mine was salvaged but i made makeshift ones!
  4. khalil
    khalil Member
    774
    its a 54 plate
  5. Boydie
    Boydie Guest
    what does that mean? I am from northern ireland and we do not use that system
  6. khalil
    khalil Member
    774
    meaning its a 2004 year model
  7. Boydie
    Boydie Guest
    ok - so, the 2004 does not come with a standard skirt
    also, what is the part number for your votex skirt? the 5 door version will not fit a 3 door or vice versa
    i think the 3dr one is 8P007""""" from memory but could be totally wrong :S I have a couple of threads i think about it if you hit the search button
    It should be a straight fit with bonder and screws - I chose not to bother with the votex rear splitter as I did not like it :S you might be btter off sourcing a 2006/7 rear bumper which has had a facelift and splitter
  8. khalil
    khalil Member
    774
  9. Boydie
    Boydie Guest
    if you have the skirt - the part number will be on it!
  10. khalil
    khalil Member
    774
    i wanted to know if i get the rear bumber skirt the votex one if it is just i glue on thing or do i need some brakets to hold it in place
  11. Boydie
    Boydie Guest
    If you get your votex rear splitter from audi, it will come with the correct braketry and instructions
    Also, if you order from audi, they will ask you your chassis number so you will get the correct splitter
  12. westtra
    westtra New Member
    20
    can you still purchase the kit or parts of it direct from audi? as I am struggling to fine the front splitter on ebay etc.
  13. Boydie
    Boydie Guest
    Took me ages to track one down on ebay and it was a damaged one!
    Havent seen the for sale on ebay since to be honest! (a year nearly)
  14. westtra
    westtra New Member
    20
    have seen 2 but not been able to get on to put last minute bid in and mt max bid has just been 2 low both times.
  15. petewon
    petewon Member
    529
    No the original skirt should come off, its a pian in the arse to get off too. Its possibly easier to remove the whole rear bumper clip the bottom bit off then clip the new one on and refit the bumper. As boydie says make sure you get the correct one as theres a few and they dont all fit between the two 8P shapes.
  16. petewon
    petewon Member
    529
