VOSA MOT HISTORY CHECK
AGU-TURBO May 4, 2011
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    Check you'r cars mot history For anybody that doesn't no about it here is the link:
    Well guys n girls ive just sold my van and the bloke who bought it thinks it has been clocked. i did do a full £10 my car check.com before i bought it and it came back saying everything is fine
    here is what it says:​
    Full Test History, starting with first recorded vehicle and test results
    Registration mark:R501PBLMake/Model:pEUGEOT / PARTNER 800Colour:WHITEVIN/Chassis No:VF35CD9BD60091185Approximate date of first use:20/03/1998Type of fuel:Diesel
    Date of test:06/12/2006Certificate issue refused (Fail)
    Odometer reading:180,425 MilesTest number:411550246499Test station name:TYRE & AUTO CENTRETest station number:6822A3Test station telephone number:01914892295Test class:IVReason(s) for refusal to issue Certificate
    Nearside Registration plate lamp not working (1.1.5c)
    Nearside Stop lamp not working (1.2.1b)
    No Advisory Notice issued
    Date of test:06/12/2006Certificate issued (Pass)
    Odometer reading:180,425 MilesTest number:460510446385Test station name:TYRE & AUTO CENTRETest station number:6822A3Test station telephone number:01914892295Test class:IVTest expiry date:05/12/2007No Advisory Notice issued
    Date of test:23/08/2007Certificate issued (Pass)
    Odometer reading:85,018 MilesTest number:344935737258Test station name:pERFORMANCE CARSTest station number:V100657Test station telephone number:0191 4242302Test class:IVTest expiry date:22/08/2008No Advisory Notice issued
    Change of details
    Make/Model:pEUGEOT / PARTNER recorded at time of test on 23/08/2007
    Date of test:26/09/2008Certificate issue refused (Fail)
    Odometer reading:69,173 MilesTest number:282350278203Test station name:pARKERSTest station number:29372Test station telephone number:01915672274Test class:IVReason(s) for refusal to issue Certificate
    Both Front position lamp(s) not working (1.1.A.2b)
    Front both Brake disc(s) excessively pitted (3.5.1h) **DANGEROUS**
    Nearside Rear Brake pipe excessively corroded (3.6.B.2c) **DANGEROUS**
    Brake load sensing valve linkage seized (3.6.E.4) **DANGEROUS**
    Offside Front Coil spring corroded (2.4.C.1b)
    Change of details
    Make/Model:pEUGEOT / PARTNER 800 recorded at time of test on 26/09/2008
    Date of test:29/09/2008Certificate issued (Pass)
    Odometer reading:69,177 MilesTest number:311133778280Test station name:pARKERSTest station number:29372Test station telephone number:01915672274Test class:IVTest expiry date:28/09/2009Advisory Notice issued
    Date of test:07/09/2009Certificate issue refused (Fail)
    Odometer reading:11,754 MilesTest number:442330459253Test station name:DCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVReason(s) for refusal to issue Certificate
    Nearside Front position lamp(s) not working (1.1.A.2b)
    Offside Outer Front constant velocity joint gaiter split (2.5.C.1a)
    Nearside Outer Front constant velocity joint gaiter split (2.5.C.1a)
    Rear Tyre(s) is incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
    Offside Front Direction indicators slightly discoloured (1.4.A.2d)
    Exhaust has part of the system slightly deteriorated (7.1.1a)
    Change of details
    Make/Model:pEUGEOT / PARTNER recorded at time of test on 07/09/2009
    Date of test:25/09/2009Certificate issue refused (Fail)
    Odometer reading:117,578 MilesTest number:773338169254Test station name:DCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVReason(s) for refusal to issue Certificate
    Nearside Front All position lamps not working (1.1.A.2b)
    Front number plate has slight damage
    Date of test:25/09/2009Certificate issued (Pass)
    Odometer reading:117,578 MilesTest number:660418669260Test station name:DCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVTest expiry date:28/09/2010Advisory Notice issued
    Date of test:11/09/2010Certificate issue refused (Fail)
    Odometer reading:122,320 MilesTest number:681064050295Test station name:HILLSIDE GARAGETest station number:1ALK81Test station telephone number:Tel. 01246 828790Test class:IVReason(s) for refusal to issue Certificate
    Rear Exhaust system not adequately supported (7.1.1b)
    Rear Spare wheel carrier insecure (6.4.2)
    Nearside Outer Front constant velocity joint gaiter deteriorated (2.5.C.1a)
    Offside Inner Ball joint has slight play (2.2.B.1f)
    Nearside Inner Front wing Body has slight corrosion (6.1.3)
    Offside Inner Front wing Body has slight corrosion (6.1.3)
    Engine/gearbox mounting(s) defective
    Oil leak
    Date of test:14/09/2010Certificate issued (Pass)
    Odometer reading:122,352 MilesTest number:723767450296Test station name:HILLSIDE GARAGETest station number:1ALK81Test station telephone number:Tel. 01246 828790Test class:IVTest expiry date:28/09/2011Advisory Notice issued
    Oil leak
    tell me what you all think, there is definetly mistakes been made by MOT testers at some point but it goes abit beyond that me thinks. let me no you'r thoughts
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    My mate just bought an A4 1.9d for a run about, seemed like a bargain at the time. After about a week he thought he`d do one of these checks as the car only came with 2 MOT`s and no other history. Turns out it was MOT`d in 05 with 130k and then MOT`d in 06 with 75k meaning the bargain he thought he`d got turned out to be an overpriced 160k miler. Gutted he was but we think its been done by the owner previous to who he bought it from.
    Looking at yours i take it the issue is where it drops to 11k instead of 100k something. If he think its been clocked has he not looked at the next MOT mileage. Its not going to jump up from 11k to 117 in a year is it lol. Clearly a mistake made by the tester.
  3. Mings
    Mings A3 1.8T Sport
    77
    Looks like it was clocked between 2006 and 2007 no? :/
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Thats pretty much the size of it, lets be fair. Thats a pretty big mistake to make.
  5. AGU-TURBO
    616
  6. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    thats gotta be a typo surely
  7. AGU-TURBO
    616
  8. AGU-TURBO
    616
    i don't no mate but the bloke i sold the van to aint happy lol, i might ring dvla to see if they can point some light on it.
  9. AGU-TURBO
    616
    just noticed this 2009 it went for mot with 11k failed and came back with 117
  10. AGU-TURBO
    616
    left is actual reading and right is what i think it should be, what you think?
    2006 180k - 80k
    2007 85k - 85k
    2008 69k -
    2009 117k - 117k
    2010 122k - 122k
  11. Mings
    Mings A3 1.8T Sport
    77
    Yeah that makes sense, guess the only way to get a definitive answer would be to pop down the test centre where it was MoT'd and ask. Even if they're telling porkies you may be able to get something from their manner and body language!
  12. AGU-TURBO
    616
  13. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    its worth pointing out - this is one check everyone should do regardless of the vehicles stated and documented history.
    Anyone can document anything these days - proove as much as you can and get peace of mind.
  14. AGU-TURBO
    616
    yes definitely
  15. audi-tk
    audi-tk Member
    441
    phhewww glad to se emine aint been clocked back. but the velocity gaiter has popped up a few times as not securely fitted .what is that?
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    CV joint on the drive shaft (constant velocity)
  17. audi-tk
    audi-tk Member
    441
    thanks mate how come it says not fitted securely. ive had a new driveshaft since so should be ok now :)
