Volume Button Stuck in
Good 2 B A Gooner Oct 22, 2009
  1. Hi all,
    My volume button is stuck in on my Concert CD player - Anyone come across this before, Know how to get it back out...?!
    Cheers,
    Gary. :icon_thumright:
  2. Brianx5
    Brianx5 New Member
    HI, I had this on my concert unit and found out that the button is on a spline and it has been pushed in to far so if you Gently pull it back it will work again
    Brian
  3. NHN
    29,509
    1,764
    Damn thats a bittttccch of a problem, if it doesnt come out, then remove radio & then fascia, then I suspect as per older concerts, you can unscrew the fascia parts to get to the knob itself to pull it out & resolve the issue, if you intend to use a pair of long nose pliers get some kitchen towel or thin cloth on it 1st obviously, so you dont strip the nice matt/rubberised coating on the knobs
  4. Just got arround to fixing the stereo... Easy as pie!! i did try to remove the fascia but it had tiny torque bolts - So i used the other option, pulled the button and i was just the housing inside the button had dropped, pulled it out and re-seated it, all now ok! Touch....
