Voice Control worthwhile option or not?
Andy27168 Apr 29, 2013
  1. Andy27168
    Andy27168 Member
    130
    9
    Hi,
    Having recently bought my first Audi a 2006 Audi A4 Convertible Quattro Sport 3.0 TDI, Six Speed Manual, its got some nice options inc. RNS-E Sat Nav with OEM Bluetooth, and have been considering additional ones. One of which is the OEM voice control, has anyone else done this mod, is it worth it or would I be better off spending my money on something else. Anyone suggest who the best people to do it?
  2. NHN
    29,298
    1,701
    I use it everyday, so for me for safety & convenience whilst driving, its totally worthwhile.
    We install this system if of interest.
  3. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,114
    2,569
    Nigel
    What does the voice control cover? Is it just for making and answering calls, or does it also control navigation; i.e. entering routes etc?
  4. NHN
    29,298
    1,701
    Depends on the level you have, if you have mfsw & BT, then its sds low just for phone, if you have the correct rns, mfsw & bt, then you can have the high version that covers nav, bt & radio.
  5. ricostuart
    ricostuart Active Member
    409
    43
    i did the SDS hack to my RNSE a week or so ago. Bit of a bugger wiring wise (couldnt get the RNSE head unit out), but other than that its fairly easy.
    The only problem I have is not knowing the commands, or have a command list to refer to. You can ask help when using it, but to me thats not great. Defo worth while if you have the time as it costs next to nothing to do.
  6. Amason007
    Amason007 Member
    116
    41
    Nigel(NHN) did this for me. I must have the High Version as I have Nav, BT & Radio. Wouldn't be without it now. A real cool feature I think as well as "safety & convenience whilst driving". Very worthwhile and not that expensive.
    Andy
    NHN likes this.
  7. jdp1962
    8,114
    2,569
    I have a 2007 (57-reg) B7 A4 saloon with OEM RNSE and bluetooth, but no multi-function steering wheel. I love the RNSE, but have always found it fiddly to use on the move because I have to take my eyes off the road and one hand off the wheel. So a lot of the time, I tend not to bother with Nav, outbound calls or SD cards, and just use the radio, and bluetooth for inbound calls.
  8. jdp1962
    8,114
    2,569
    How much was "not that expensive" in your case?
  9. NHN
    29,298
    1,701
    You'd need an mfsw to utilise the system properly, so normal sds costs would have the addition of the wheel & maybe modules.
  10. jdp1962
    8,114
    2,569
    OK, cheers, Nigel.
  11. NHN
    29,298
    1,701
    I have a complete wheel with airbag & paddles available if of interest.
  12. jdp1962
    8,114
    2,569
    Ooooh, it's tempting, Nigel, but I'll pass.
    (for the moment)
  13. ricostuart
    409
    43
    ignoring the aircraft grade connector blocks and wiring that i used, about £5 for the audi repair wires. :)
  14. Andy27168
    Andy27168 Member
    130
    9
    Cheers for all the replies, Sounds like quite a worthwhile option then, what i was frightened off was a system that had recognition problems similar to that other major German manufacturer. NHN how can I tell how much functionality I would get on my car it has the RNSE OEM Bluetooth and a MFSW? and was registered in March 2006. What sort of price are you looking at to install this? as I would rather give my hard earned to a fellow forum member or a forum sponsor, have you a web site?
  15. NHN
    29,298
    1,701
    Ping me a PM please.
    You would get phone, Nav & Radio voice usage & it all comes down to how you use it, but I've fitted for varied nationalities (including scousers) & they all got used to the system & understood them ok.
    Geebo likes this.
  16. Andy27168
    Andy27168 Member
    130
    9
    Cheers, PM Sent
  17. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,989
    754
    It's 100% worth it, couldn't be without now.........
    Take it from me ^^^ Nigel (NHN) is yer man, top bloke, top work
    Geebo and Sandra like this.
  18. Andy27168
    Andy27168 Member
    130
    9
    Cheers for the heads up Mac, I think after this thread Voice control is going to the top of my "to do" list :), together with footwell lighting, puddle lights and Cruise Control.
  19. Andy27168
    Andy27168 Member
    130
    9
    Well having looked around on the forum at the retro-fits that were possible I decided to buy a VCDS cable off of NHN, Thanks Nigel.
    I have now had Cruise Control fitted and coded, Puddle lights fitted (though I have an unknown fault with the passenger door at the moment) and whilst playing with VCDS I activated the SDS.
    So that's two and a bit mods of my list.
    Having done a lot of retro fits on my other car, I,m going to attempt to do the high end SDS hack fit, I have got a copy of the 650 & 660 SDS Software, and I,m aware that I will have to wire the microphone straight into the RNSE, and then to the Bluetooth module.
    I intend to locate my existing mic cable cut it and splice both ends with some mic cable and route it to the RNSE, pin up the ends, and fit them into the mic in & out connections. I have made an assumption that my existing mic cable is a two core screened cable, but I,m at a loss where to connect the screen on the "C" connector, indeed should I even connect it.
    I have used the search function but I cannot find any definitive answers or they are conflicting,
    what I would like to know is,
    Where is the Bluetooth module located on a 2006 B7 Cab?
    The mic is in the overhead light fitting, and the cable I think is run down the passenger side "A" pillar, can anyone confirm that this is correct?
    Indeed any advice on doing this would be welcome.
  20. NHN
    29,298
    1,701
    Mic wire runs down as you say passenger a pillar, just cut into in that pillar, it is actually a coaxial, so inner & out, whereas the 8P has an actual green & black wire inside a black covering, then wire from there, no need to touch the BT module.
    Andy27168 likes this.
  21. Geebo
    Geebo Member
    50
    24
    Nigel is indeed a great guy & very knowledgeable. His attention to detail which I guess comes from his vast experience is second to none. He fitted the newer RNS, AMI & voice control to my 2006 B7 A4 3.0 TDI quattro cab. I also use it every day & for me it's a brilliant & worthwhile mod. I agree the multi function steering wheel is a must.
    NHN likes this.
  22. Andy27168
    Andy27168 Member
    130
    9
    Whats AMI?
    "Edit" Just answered my own question by googling it doh, Audi Music Interface, is this possible and still have a CD Changer? I was going to install an Aux in 3.5mm socket straight from the RNSE Aux in connections is this the same/similar thing?
  23. Geebo
    Geebo Member
    50
    24
    The AMI unit is fitted where the cd multi changer was in the glove box. I don't personally use cd's anymore so the AMI with iPod lead made more sense to me. Having said that the mk II RNS will take two 32Gb SD cards so theres plenty of scope for music storage there too.
  24. Eyeball74
    Eyeball74 New Member
    29
    Hi all. I have an 54 plate a6 saloon with nav, Bluetooth, radio ect and multifunction steering wheel. However, when I press the voice button on the right hand side of wheel nothing happens. No beep, no nothing. In my manual it mentions about voice activation but I can't get it to work.. Any help would be gratefull.
  25. s8craig
    1,746
    53
    Chances are if you have Bluetooth the software is too old and the voice control is not enabled.
    Early A6's were switched off.
    Check your MMI version and report back, press CAR and then VERSION and report back the top line.
  26. Eyeball74
    29
    SW:C6-HU 6350 05.0.0 0413
  27. Eyeball74
    29
  28. s8craig
    1,746
    53
    Software 0500, yes very old. Highest version available is 5570.
    So I would get the car updated, you can buy disks and do it yourself or get a professional to do it for you.
    I did an A8 from 0350 to 5570 yesterday it took 2 hours, and it has to be done in stages form 0350, it went wrong and trashed the MMI controller firmware, but I managed to recover it using a few tricks, so be careful.
    Typical issues when you update are...
    Trashed phone ECU
    Trashed AMP or AMP in component protection requiring a dealer visit.
    Lost Instrument cluster and battery settings from the car menu ( can be fixed with VCDS)
    I can't remember exactly but I think 0500 can go directly to 5150 then to 5570.
    But if not it has to go 0500 to 1100 to 5150 to 5570
    gupsterg likes this.
  29. Eyeball74
    29
    Ah, ok. Might give it a miss then. Would be handy to have but sounds risky. Wouldn't know how to upgrade anyway. Thanks.
  30. s8craig
    1,746
    53
    Well I would get it done anyway as you will get extra features in the MMI.
    1. 3D views in the mapping
    2. TMC will work.
    3. Fixes for the Bluetooth getting improved phone compatibility
    4. Enables voices control
    gupsterg and NHN like this.
  31. Andy27168
    Andy27168 Member
    130
    9
    Hi,
    Well I finally got round to rerouting my phone mic today but I quickly come to a halt.
    I removed the RNSE and glove box no problems at all, but I cannot locate my existing mic cable to splice into. Now I "thought" my Bluetooth unit was under my passenger seat, so I removed the passenger side kick panel, to reveal a whole bank of connectors and looms, and thinking this is where the mic cable would routed to the Bluetooth unit, and where I intended to splice the mic cable.
    Well it seems its not there after referring to the workshop manual "I think" the Bluetooth unit is on the drivers side under seat (confusion in manual with drivers and passenger side on LHD and RHD cars). Can anyone confirm this?
    I recapped on this thread and NHN referred to removing the "A" pillar windscreen trim, and splicing behind here, I tried to remove mine and it seems to come off so far but was really making some horrific cracking noises, so I stopped frightened I was going to break it.
    Can anybody help in telling me how this trim comes in one piece?
  32. NHN
    29,298
    1,701
    1st remove the light assembly & check which side the mic wire goes down, then remove grab handle of that side, then the little airbag cap label & behind this is one bolt, then sun visor, then you need to slowly prise it away towards the center of the car at the top, then once the fixings have popped out, pull it up & out, its very fiddly tbh, so be careful you don't break anything.
    If you aren't to keen, then we can do it for you :)
  33. matthew999
    matthew999 Member
    145
  34. Andy27168
    Andy27168 Member
    130
    9
    I think you are confused Nigel I have a Cabriolet, so no grab handle.
    The Mic cable definetly run down the LHS A piller, I really wanted to avoid removing the A piller trim, so I thought I would pick the cable up at the connector blocks behind the footwell trim, well mine is definetly not there making me think that maybe my Bluetooth box is on the drivers side, and the cable runs across the dash and never dropping down to the footwell connection point, but if thats the case why did,nt they run the mic cable down the drivers side A piller?? (confused).
    So hence why I decide to try to remove the passenger side trim and splice there, just not sure how to completely remove the trim, as it doesnt seem to want to release :(
  35. Steve77
    Steve77 Member
    69
    I'd be interested in this Nigel. What sort of price are we looking at?
  36. NHN
    29,298
    1,701
    Depends on what's fitted already, do you have an rns-e, what year is your car?
  37. Steve77
    Steve77 Member
    69
    ok. So I have a 2006 Cab. It has the Audi Navigation. I think it is a BNS.... Does that sound right?
    ideally I want to put in the RNS-E & Bluetooth.
    Steve
  38. NHN
    29,298
    1,701
    Well ping me a PM, I can install do rns-e, bt & sds, needs an mfsw as a prerequisite aswell for sds.
  39. Steve77
    Steve77 Member
    69
    Perfect, thanks. Have sent you a PM. I also forgot to say I have a MFSW. :)
  40. Steve77
    Steve77 Member
    69
    hey Nigel, did my PM reach you ok?
