Voice Control HELP
HUgradar Apr 27, 2011
  1. HUgradar
    HUgradar Member
    HI
    I have an 2010 A3 S Line and had Audi fit in the After Market SatNav system.
    Everything works on there fine but my Speech recognition System does not seem to work
    Audi have said it don't work because it is an after market fit but if i press the Speech button on the Wheel it does speak asking for me to say a command
    but no matter what i say it does not recognize it
    Is there anything i can do to get this working?
    if you need any more info please let me know
  2. s8craig
    1,756
    56
    Typical bad installation, the person putting in the NAV unit for you has not either removed the SDS or wired your car correctly to use it.
    So basically you have an SDS Nav unit with no mic attached, do you have BT prep as well, as if you do then he's buggered your SDS in your phone system too by being a bad installer and not knowing what he's doing, was it supplied by Blackburn audi?.
    Go in there and give them some stick and tell them to sort it out correctly.
  3. HUgradar
    HUgradar Member
    It was Bolton Audi
    Well i think it was done by someone for Bolton Audi as in someone they give all there work too.
    they wont sort it out its been a year and ive had enough of dealing with Bolton Audi
    Blackburn Audi are ace! ...
    can it be done by anyone else?
  4. s8craig
    1,756
    56
    Bring it over and I can sort it for you, shouldn't take too long.
  5. HUgradar
    HUgradar Member
    you from Manchester?
    how much would it be?
  6. s8craig
    1,756
    56
    If it's just coding I can do it for free, if I suspect you need a mic then maybe £20.
  7. HUgradar
    HUgradar Member
    cheers mate
    when's best day for you?
  8. s8craig
    1,756
    56
    On Saturday or Sunday as I will be at home fitting TV and reverse camera to my car.
    PM me for details or use the link to my website to contact me.
