  1. markyp2002
    markyp2002 Member
    311
    where is my VIN number located? A3 2001 T Sport ?
  2. rickparmar
    rickparmar Active Member
    2,332
    14
    should be on the left or right corner of the windscreen
    look from the outside
  3. rodenal
    rodenal Active Member
    1,992
    or in the bootwell or under the bonnet
  4. simch
    simch Active Member
    2,028
    On the windscreen as said and on a sticker in the boot floor which should match to the sticker in the service manual.
    Its also stamped on the top of the firewall in the engine bay, sort fo drivers side to the middle, and should be visible througha clear plastic window on the platic scuttle pkanel. If dirty, you may need to carefully lift the scuttle panel to see it, DONT lift the clear plastic, it will shatter!!
    Interestingly enough on prefacelift cars, this number si clearly stamped direct into the metal on the firewall. On facelift cars (pretty sure, certainly 2002 cars on) is seems ot be stamped into a weird factory fitted soft metal "sticker style strip and is brighter ands easier to see. Forst time I noticed it I panicked, it looked real dodgy like it had been doctored (cheers audi dealer I thought!!) but a check on other facelift cars shows this is who they do it now!
    Sort fo scary though, if plod ever looked hard at it, he may talke you in cos it looks well sus!
