vibrations/shaking when driving off
abdus Aug 29, 2007
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    Don't know if someone can help on this, but this is becoming more and more often now, when the car starts to move/drive off, there is a lot of vibrations on the front esp if I release the clutch quickly...same in 2nd, 3rd...
    any ideas? Thanks
  2. robby
    robby Active Member
    579
    69
    clutch on way out?
    engine mounts loose/ worn?
  3. abdus
    1,827
    what are the signs when the clutch is on the way out?
    btw, if I press the throttle more and then slowly release the clutch, it doesn't happen...seems to be near the wheels. or under the engine bay
    I even thought it was wheel alignment/balance;had it all checked.
  4. Lovegroover
    Lovegroover Member
    155
    Sounds like flywheel symptoms! Have a search there's loads of info on here about them...HTH
  5. abdus
    1,827
    yeah, i've read somethreads about the flywheel after I posted this one....
