Vibration when in D or R
vinesh May 6, 2010
  1. vinesh
    vinesh Member
    214
    Hi,
    I am having some issues with my A4.
    I have a multitronic 1.9tdi.
    When the car is in D or R the car vibrates but as soon you put it into P or N its nice and smooth.
    When the car is in motion, ie when doing low speeds and when on the motorway I do feel a very small amount of vibration
    Makes no difference if the AC is on or off
    No CEL errors - checked with VAGCOM
    Multitronic Oil change -
    1st one @ 39k
    2nd one @ 60k
    3rd one @ 79k (Done 2 weeks ago)
    Wheel sensors have been cleaned.
    I think some sort of mount is gone, maybe a gearbox mount?
    Any advice on this?
  2. Digger1
    Digger1 Member
    439
    Is it juddering on take off ?
    as you probably now, there is an issue with the input-shaft on the multi-box, needing the seven clutch up-grade
    especially on high torque diesels...
  3. vinesh
    vinesh Member
    214
    There is a bit of judder when taking off.
    How much is a new 7 plate clutch?
  4. Digger1
    Digger1 Member
    439
  5. vinesh
    vinesh Member
    214
    Car vibrates when cold or hot.
  6. Digger1
    Digger1 Member
    439
    May not be that, but maybe worth getting checked, they tested it before carrying out the work !
  7. vinesh
    vinesh Member
    214
    The car also vibrates (Pendulum feeling) when on the motorway.
    I'm hoping its a engine/gearbox mount.
  8. markyzs180
    markyzs180 Member
    543
    sounds like engine mount....fingers crossed it is bud...
  9. Digger1
    Digger1 Member
    439
    If you put it into neutral and coast but keep the RPM ., high, is it still there ?
    to check if it's Multi-Box related...
  10. vinesh
    vinesh Member
    214
    Just hope it is.
    Do all A4's have engine mounts with solenoids that stiffen up?
    My scan on vagcom did not flag up the engine mounts.
    Might be the gearbox mount - fingers crossed.
  11. vinesh
    vinesh Member
    214
    I've not tried that. Will try it tomorrow when I drop the wife in the morning (Roads will be clear :) )
    Cheers mate.
  12. donsajid
    donsajid Member
    I hate to say it, but that could be an early sign of transmission failiure as happened to me earlier this year. Look out for PRND on the dashboard flashing or acting erratically. It could very well be the clutch plate issue with the 7 plate conversion and I'm sure you must have heard of inde-tech in milton keynes, by all accounts they seem to know their stuff.....
  13. vinesh
    vinesh Member
    214
    The Gearbox ECU was replaced when the car had 40k on the clock (Done by Audi).
    Heard of Inde Tech and not too far from Leicester.
    Will see my local mechanic for the mounts.
