Vibration when idling
matt a4s line Sep 17, 2012
  1. matt a4s line
    matt a4s line New Member
    24
    Hi There Have a slight problem with my 2005 a4 2.0 tdi pd, The problem is vibration when at idle, the car drives faultless and pulls great but when stationary say at a set of traffic lights i can feel vibrations from the engine through my seat. Heres what I have done so far
    Injector cleaner
    Full service
    Remap to 175bhp
    Egr valve clean.
    New clutch and flywheel 10k ago
    Full engine rebuild to the new gear driven balance shafts 20k ago
    Timing belt done with proper lockers
    I have heard this can be a trait of these engines? however I think mine is slightly worse than most people suggest worn camshafts, injectors, not enough fuel at idle etc.....Any Ideas where to next? anyone had the same issues and found a solution?
    Cheers matthew
  2. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Rock the engine on its mounts when turned off. It may be your engine mounts are worn. I had this issue on my old Golf. Although you could hear it knocking when moving off too.
  3. williams
    williams Member
    78
    would be nice to find out as well as mine does the same,audi said its got cracked inlet manifold check it nothing wrong with it and they wanted £970 to if one.
  4. gas-man
    gas-man Member
    215
    got the same thing happening to mine
    took it in for a service last thurs
    the guy put it on the computer to reset the service and done a few checks
    he said that number 3 glow plug was off slightly and drawing a bit to much power
    he said that it could be this thats causing the vibration on tick over
    will let you know when he does it for me
  5. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Is this on the 3.0TDI engine, I'm getting some vibrations on mine but nothing too concerning. I just thought it was present due to the size of the engine itself.
  6. snapon
    snapon Member
    37
    might be worth getting it scanned with VCDS to see if there is a misfire happening on idle
  7. b19rak
    b19rak Member
    46
    This is part and parcel of this engine. Mine does exactly the same when cold with white smoke. Pulls like a train and 48mpg 170 tdi.
  8. mm707
    mm707 Member
    267
    10
    Mine used to have a really lumpy tickover. Anyway I changed the vacuum unit on the inlet manifold because I was getting limp mode with underboost issues etc. Whilst apart I spent ages cleaning all the crud from the flaps on the inlet manifold and the egr ( egr not too bad though as only 18 months old ). Now runs perfectly - no lumpy tickover - could be the vac unit ( which did have a hole in the diaphragm when inspected ) or most likely just the cleaning.
    2.0 tdi 170
  9. craiga
    craiga Member
    45
    Mines is the same (2.0 tdi 170).As said above part and parcel of the engine!!! According to audi!!!!
