Vibration from the diff?
DAZ1985 Jan 19, 2012
  1. DAZ1985
    DAZ1985 Member
    124
    I have a vibrating noise from the diff (sounds like its dragging) when in first gear on full lock?
    I have changed the diff oil (used genuine Audi stuff)
    Made no difference
    Seems to get louder when it's warm after a long journey
    If the diff is shot :( would a diff off an allroad a6 fit?
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,800
    50
    all i know about diffs is its best to change "like 4 like" as they can off set your speedo and quattro set up,
  3. towcestervag
    towcestervag Member VCDS Map User
    165
    they all do it
    test drive another but they all make a noise on full lock pull away
  4. DAZ1985
    DAZ1985 Member
    124
    It's the same engine, just auto on the allroad mines manual, but I'll take that on board. Thanks
  5. olly quattro
    olly quattro Member
    78
    They defo all do it
  6. DAZ1985
    DAZ1985 Member
    124
    Seems strange they all do it, sounds wrong.
    Is their a reason why? Or should I stop worrying about it and accept it how it is?
  7. towcestervag
    165
    its the diff winding up
    it working hard when on full lock
    if you think 1 wheel is nearly stationary and the other is moving quite a distance so the diff is working at its optimum hence the noise
    been with audi since the original quattro and before and they have all made this noise
    So dont worry!
  8. DAZ1985
    DAZ1985 Member
    124
    Reason I ask is me dads s3 doesn't make the same noise, nothing like it
  9. jbcalvin
    jbcalvin Member
    691
    21
    4WD drive system on the S3 is totally different to the A4, S3's are FWD until slip happens and then power sent to the back using the haldex system......
    A4's use old school permanent 4WD with torsen front/centre/rear mechanical diffs which are pretty much bombproof, worked for VAG for over 10 years, never saw a diff failure......
  10. quattro tony
    quattro tony Member
    167
    I know the s3 doesnt have the same diff as the a4. The s3 has a haldex which only sends power to the rear wheels when required so most of the power is sent to the front in normal conditions.How old is ur dad's s3 btw?
  11. DAZ1985
    DAZ1985 Member
    124
    If you all it's fine I'll go with that
    S3 on a 59 plate tony
  12. quattro tony
    quattro tony Member
    167
    S3 still should be a haldex as mentioned above. I would go test mine and report bk but i carn't as ive just traded my a4 quattro in :bye: , i think mine did it on full lock aswell.
