vibration from rear on full lock 2001 s3 help!
fezzers Jan 3, 2012
  1. fezzers
    fezzers New Member
    12
    hi ive recently purchased a y reg s3 209bhp, i am a mechanic by trade but i havent had alot to do with the 4 wheel drive system on these cars. now i may have brought this car without realising a few things.... the center display has 3 areas the top one isnt working an after buying it ive realised thats where the faults are indicated also the stereo is in safe mode would this affect it?. does anyone no if these can be turned off or maybe bulb removed? also im getting a vibration almost like the rear diff is locking up on full lock but only at low speeds (ie car parks or 3 point turns etc). since ive noticed these problems ive been looking on the net to see if theres any info on it cant find much, any help would be much appreciated. ive just got a heldex filter and oil planning to change it tomorrow. im starting to get a bit worried that it could be a complete rear diff etc. hopefully someone will have come across this before! thanks
  2. <tuffty/>
    20,847
    3,687
    Hi and welcome to ASN...
    The symptoms you describe sound like sticking haldex clutch plates due to a lack of proper haldex oil changes... you maybe lucky and recover it by doing a haldex oil and filter change... I would be tempted to do it again after a few thousand miles too to clear it through... not a difficult task tbh... oil is cheap enough...
    This is a seemingly common complaint on older S3's as they become cheaper and owners are not doing dealer services so haldex services get missed...
    Worse case is a replacement haldex clutch sadly..
  3. fezzers
    fezzers New Member
    12
    any ideas how much that will cost if that happens to be the case? i thought i had a reasonable deal at first i only paid 2750 for it spent a bit on 2 new cv boots, rear spring, heldex oil an filter, fog light grill but its only done 117k for the age thats ok, serviced at audi up to 77 then a private garage at 93 and 116, from what i can see the heldex has only been changed once though ! i hope the oil fixes it. any ideas on the dash ? thanks
  4. patTTpoa
    patTTpoa Member
    793
    If your getting a garage to service the diff (haldex clutches) then you're looking at a lot of money!
    You would be better off getting a second hand diff.
    But as tuffty has said do a few oil & filter changes first before getting carried away thinking about clutches & diff's.
    Good luck
    Pat
  5. ROBBerto84
    ROBBerto84 Member
    sorry to hijack a little but I very occasionally get this vibration from the rear passenger side, Y reg 209bhp S3, 108k miles. Up until the last service (done by the garage I bought it from) it has all Audi stamps, they should have done the Haldex as and when they themselves recommend, no?
  6. fezzers
    fezzers New Member
    12
    i got a duplicate service booklet off audi the other day and only one heldex service was done according to it and that was early in its life which is pretty bad considering they are a main dealer! i work for toyota so will do any work myself on it if i have to. i thought buying an audi would be easy days as ive had enough of working on my own cars! but then again it was cheap. your prob right Pat not to jump the gun yet,i never seem to have much luck though! lol thanks for the advice ill keep u up to date.
  7. Pedrosousa
    Pedrosousa Member
    174
    I had this problem, changed oil an filter and it was good for about 10.000km... Now it's starting again some time it does other don't.
    Changing the oil again could be a solution??
  8. Ian W
    Ian W Active Member
    1,058
    12
    I had this problem, think it was on my old S3.
    Either way, haldex oil and filter change sorted it.
  9. fezzers
    fezzers New Member
    12
    cheers guys changed the oil an filter today gonna try it in the morning, the heldex filter looked dirty,the oil didnt look the best either. i did notice before doing it it was fine when cold and started doing it after id driven it so hopefully the oil change will sort it. another thing the new heldex filter looked different to the one i took out. the one i took out had small filter attached, the new one looked different like the filter was intergrated into the actual plastic. is this a new design?
  10. <tuffty/>
    20,847
    3,687
    Christ!! if you had the metal style filter it can't have been changed in ages... been plastic filters for some time now..
    This thread maybe of some use to you too...
    www.audi-sport.net/vb/a3-s3-forum-8l-chassis/143983-sounds-expensive-lol.html
