Vibration from Front Right Wheel on a Left Turn! Driving me mad! Please Help...
PhilM81 Apr 23, 2012
  1. PhilM81
    PhilM81 Quattro, bring on the SNOW!
    84
    Hi all,
    Can anyone help to diagnose this fault!!? Been to two garages and an Audi main dealer, still no joy.
    When I turn left at ~20MPH+ I get a loud vibration/knocking from the right front wheel. Sounds rotational, and non-metallic.
    Also doenst happen when turning right or straight!?
    Checked wheel arch liner and nothing is touching the wheel on left or right locks. Also there is no play in the wheel to suggest bearings.
    Thought it could be something to do with the anti-roll bar, as it happens on corners when there is a slight roll on the car.
    Seriously this is driving me mad and im not able to enjoy driving.
    Anyone experianced similar or can think of what it could be?
    Car is A3 Sline Quatrro TDI170, 57 plate, 3dr, 18" aftermarket wheels, eibach prokit suspension (happened also before this was fitted).
    Many thanks in advance. Phil.
  2. PhilM81
    84
    Gutted!
    Replaced front off side drive shaft which includes cv joint, but still vibrating from the right wheel on left turns ???!
    Any techies out there that can help to diagnose??
    Thanks,
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i woulda put it down to the drive shaft is your car quattro, unlikely but could be vibration though the propshaft may be worth trying it off
  4. Sliding-R
    Sliding-R New Member
    Wheel bearing?
    Jack the car up and feel the suspect wheel for play up and down and side to side.
    Get someone to watch from underneath and see where the slop is if any.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    he did say there is no play in them though probably worth another check
  6. PhilM81
    84
    Yes it's a Quattro, will try to wriggle test tomorrow! Cheers
  7. bagey
    bagey aud you do !
    198
    have you tried swapping wheels over ? , also just had some work done on car and the engine mount was moved slightly which caused a knocking noise when turning left . hope you get it sorted fella
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    goood idea above let us know how you get on
  9. PhilM81
    84
    Update... Swapped the front wheel for the spare and it still makes the vibration sound!! FFS
  10. bagey
    bagey aud you do !
    198
    dont suppose you can record the noise with anything ? ie phone and upload it onto here ? nothing loose in engine bay ?
  11. PhilM81
    84
    Fixed! Cause was the engine mounts, new ones fitted today and she drives like a dream! ahhhhhhh.
  12. Dangray
    Dangray New Member
    I think I have the same problem by its only when I turn right , what mounts did you change ?
  13. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Doubt he'll reply, he hasn't been on for 2 years.
    Adam_A3_ likes this.
