very bouncy ride with coilovers advice?
8385HJ Feb 13, 2012
  1. 8385HJ
    8385HJ Member
    101
    I had fk ak street coilovers fitted on my a3 and the ride is horribly bouncy especially on the motorway any advice on what I should do to remedy this without getting new coilovers or refitting my sline suspension
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,065
    224
    How low do you have them set?
    Damian @ DPM Performance
  3. 8385HJ
    8385HJ Member
    101
    At the moment the distance between the bottom of the arch to the centre of the wheel is 12.5cm all around and I have 25mm of thread left to wind down
  4. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Do you know how much lower you are running than standard?
    When I had some Bilstein coilovers fitted on a Leon Cupra R some years back they took some time to bed in and settle so after about a 1000 miles they were more compliant than in the first few days after fitting.
  5. Indy
    Indy Member
    119
    Also, remember that the lower you go the worse/bouncier the ride will become, as there is less travel in the springs to absorb shocks and bumps.
  6. 8385HJ
    8385HJ Member
    101
    Unfortunately not it is an SLine if that helps at all I'm guessing probably around 80mm lower than standard so 60mm lower than s-line
  7. warren_S5
    7,210
    2,488
    Then there is your answer. Surely that's got to be way too low to expect any ride quality. I think the S-Line and S3 are same ride height. I wouldn't lower an S3 more than 20mm to retain some ride quality, so yours must be very low.
    Do you have to use shortened bump stops to run that ride height?
  8. 8385HJ
    8385HJ Member
    101
    I used whatever was provided by the coilover manufacturer I am not 100% sure, in your opinion would I be better off running lowering springs and the sline shocks?
  9. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    Must be too low mate raise her up a bit , the S3 is 15mm lower than the s-line as far as I know
  10. warren_S5
    7,210
    2,488
    Coils should be fine, but adjust them to raise the ride height.
    They're never going to ride like a spring / damper set up but then that's not why someone buys coilovers, its for the ride height adjustability.
    I'm not sure how yours will adjust ride height, so you will need to refer to your instructions.
  11. DPM
    5,065
    224
    As mentioned try raising them up.
  12. 8385HJ
    8385HJ Member
    101
    Would anyone be kind enough to measure the distance between the bottom of the arch and centre of the wheel of an s3 sportback please
