Very blonde moment, followed by coolant in the washer reservoir
PhysicsFool Dec 12, 2012
  1. PhysicsFool
    PhysicsFool New Member
    9
    How do I acces the drain plug on the windscreen washer reservoir? Is it a case of removing the front left wheel and undoing the wheel arch panels? she's a 99 a4 1.8t sport.
  2. NineNails
    NineNails Proud sponsor of the snack food industry
    583
    There isn't one. Best thing to do would br to siphon it out with a length of pipe I guess. Most antifreeze says to wipe off if you get it on paint work so don't be tempted to just run it through the system
  3. aragorn
    18,019
    716
    pull the pump out and it'll drain!
  4. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    take the filter out, stick a hose in, leave it running for a few mins
  5. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Can you not disconnect the hose at the t-juntion before the jet and stick it into a bottle.
    Operate the pump to empty (bearing in mind it was not designed to run for hours on end without burning out)
    Also remember to keep the screen wet so you don't bugger the rubbers
  6. PhysicsFool
    9
    Cheers chaps, nipped to the local motosave and bought a cheeky siphon gadget for a couple of pund. siphoned all the antifreeze out and rinsed with water and then replaced with proper washer fluid. upped the concentration to overpower and remaining antifreeze. that alone constitutes a successful thursday in my books..
