Very Bad Monday Morning!
Mr.Sline Feb 24, 2014
  1. Mr.Sline
    Mr.Sline New Member
    Hi all,
    I have a much loved Audi A4 2.0 tdi sline 140bhp 2007 (BRE engine code)
    On my daily commute to work early morning my brake pedal went stiff and no brake force at
    all so had to get my hands on the handbrake to bring it to a complete stop, fortunately i was
    strolling along in traffic so it wasnt too bad, could not imagine if i was driving at normal speeds.
    Pads where changed a week ago believe it or not but im assuming its the vacuum pump, so i will
    get this sorted...
    But the story doesnt finish there....
    I then tried to limp at the bottom of the road as my work car park was 30sec away and then
    The Engine oil pressure light popped up yes the big dreaded red one!
    immediately the car was pulled over, switched off and AA was on route. He started the car up even
    though he was advised of the situation and the engine ran rough and sound quite tinny.
    So the car is sitting at the garage now, rocker cover has been taken off no oil wants to travel up
    so the sump has been taken off. The oil pump is gear driven and has a hex balance shaft...
    need any information and feedback in regards to what do i change, ideally the cost effective method
    for me is just to change the oil pump..? But will that cure it..?The whole unit including the balance shaft
    is very pricey but vag com diagnostic is not showing any further information apart from low oil pressure.
    looking into this problem on this forum and others it is a common problem, but on the blb engine code which
    is chain driven and has tensioners, so then from my information Audi upgraded these to the gear driven oil pumps
    which is in mine, so what the hell has happened to mine? :-0
    The car is always ran on the correct oil grade and it has never fell low, the car has always been warmed up
    to the normal operating temp before driving over 2k and the millage in question is 112k
    really frustrating as a major service was carried out including pads, water pump, timing belt and thermostat!
    Now this, please comment any thoughts and advice will all be much appreciated
    many thanks
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,731
    653
  3. Mr.Sline
    Mr.Sline New Member
  4. Mr.Sline
    Mr.Sline New Member
    Got this sorted :)
    The hex drive was rounded off so replaced this and this only, as after a close inspection the balance shaft was not worn and with the new hex drive in place there is no play at all so it will not slip....
    Brakes are working again, but still looking into this as the vacuum pressure is not so great, after reapplying the pedal is getting very stiff.
  5. Paul B7
    Paul B7 Active Member
    622
    34
    I am pleased you haven't killed the engine.
    Points to note are:
    1) the balance shafts don't give a problem its only the hex drive that's the achilles heal.
    2) big end bearings may have suffered and I had to have mine reshelled.
    3) Its reasonable to expect the turbo life will have been shortened, I know it did mine !
    Paul B7
  6. Darren198712
    Darren198712 Member
    194
    14
    Very bad morning but very lucky to be honest. Glad you got it sorted
