Ventilation System Has A Mind Of Its Own
mystic.bertie Nov 29, 2011
  1. mystic.bertie
    mystic.bertie Member
    66
    2001 2.5tdi, my ventilation system does what it wants, i am not using auto and i have the econ button on, but if i set the temp and the fan speed the next thing i know the fan speed is way up and making lots of noise, is this a common fault?
  2. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    Mine does this too. Auto mode off and it still seems to try decide what speed for the fan I need.
    Id also like to know other peoples ideas as to cause/ fixes.
  3. Mike B
    Mike B Well-Known Member
    1,101
    40
    Are you saying that you cant control the fan speed at all?Are all the buttons working freely ?
  4. crazy88
    4,939
    437
    On mine the buttons work 99% of the time. However, when changing from 18c to xxC for example the unit then decides to up the fan speed to max usually. Even when auto is turned off. I can then manually turn fan speed down but I wish it stayed on 3 as I usually have it. Does that make any sense?
  5. mystic.bertie
    66
    YEAH mine too all the buttons work fine, i can adjust the speed of the fan too but the next thing i know the speed is getting higher and higher,i turn it down it gets higher and higher, also its in manual mode not auto.
