  1. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group saloon TDi
    3,069
    804
    Hi All,
    After fitting my RNS-R, Rhyso has kindly offered to code it for me.
    Is there anything else good that can be 'activated' when coding?
  2. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,256
    351
    there is a list of stuff somewhere in the 8p section of things that are cool to be activated with vcds cant remember where it is tho, one touch total closure is cool instead of holding down the button to close the windows you just hold it for a second and it closes them auto , has yours got coming home/leaving lights im assuming yes as you have xenon's
  3. ScottishA4B9
    3,069
    804
    Yeah I have the coming home lights. I will have to look see what other cool things there is to activate.
  4. NCRAW
    NCRAW Member
    230
    Got a link? Il be trying out my new cable tomorrow and will be interested in trying a few extra things.
  5. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    You can also code your horn to 'chirp' when locking or unlocking the car. I did this on mine last week.
  6. MOOSH
    MOOSH Member
    253
    I would be interested in the link as well so i can get me code on :)
  7. Paullie
    2,076
    288
  8. ScottishA4B9
    3,069
    804
    Can it be programmed to do the needle sweep on start up like the newer S3's????
  9. moag
    moag she's no d-turbo
    821
    35
    I think you need the white DIS (late 07) to enable it
  10. ScottishA4B9
    3,069
    804
    WHite DIS didnt come out until the facelift models didnt it? As I test drove a 08 and a 09 plate with the red diss that both had it
  11. NCRAW
    NCRAW Member
    230
    My 2008 does that. From your avatar it looks like u have one too so should do it.
  12. NCRAW
    NCRAW Member
    230
    Guys sorry to hassle but could someone with VCDS experience help me out. I bought the cable mainly to reduce steering assistance and bring the xenon headlights up a bit.
    For the former: i read the section about steering assistance an dim all confused. it seems like in the pre06 u could actually change the amount of steering assistance but in post06 u can only change the level of steering assistance in relation to a speed value. Ok so its not as good as pre06 but i still want to change it. I'm quiet happy with how the steering wheel feels at 70+ km/hr but its the lower speeds that annoys me. How do I go about changing it. Please bear with me as i looked at the Ross Tech website and all i saw where all i can do under 44 is checking torque sensor and steering sensor but cant see steering assistance value.
    For the latter: can i adjust the xenon lights height without doing any manual adjustments?
    Many thanks
  13. NHN
    29,551
    1,777
    No you cant use vcds to adjust headlights up/down, its manual setting according to your countries mot requirements, vcds just has an mot mode to do this manually.
  14. MOOSH
    MOOSH Member
    253
  15. ScottishA4B9
    3,069
    804
    Does anybody have the codes for activating the needle sweep?
  16. mike foster
    3,967
    As far as I know mate you can't do it ! Nige will no doubt confirm or otherwise !
  17. NCRAW
    NCRAW Member
    230
    Thanks for confirming that. I saw a thread written by an A4 owner who was doing that. Basically changing a value to lift the lights a bit. He did it by dropping the value from 60 to 20. Here is a link.
    :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
  18. NHN
    29,551
    1,777
    Thats a mistake to do this, as you're effectively telling your module its an A6, if your module supports that coding in the 1st place, your choice, but I wouldnt.
  19. NCRAW
    NCRAW Member
    230
    I see. Thanks for clarifying it.
  20. NCRAW
    NCRAW Member
    230
    Alright, all sorted. Well at least the xenon lights are. After going on VCDS, and going into the xenon module, an alignment error came up that somehow Audi service managed to mask. I could not do a new adaptation and basically was stuck so went to the meas values and noticed the rear sensor was giving a very low value on flat surface (15%) while it should be between 50 and 78% I believe. So went under the car and there it was, the so called Audi mechanics, suppose to know what they are doing, who replaced my rear diff, put the sensor bar in the horizontal position rather than vertical. I was fuming and cursing. Great build quality out of Germany but i had nothing but grief everytime something went slightly wrong as they take 3-4 visits to fix it but manage to ruin something else (rear diff was replaced due to them damaging it when replacing the seals, damaged door alum trim when replaced the window regulator, new trim under warranty etc). A socket wrench and a spanner and turned the sucker around and baaam!! al back to normal, no faults, light adjusts to changes in rd heights perfectly and the xenon range is back to what it used to be. Thank god the warranty and free service period is over and now i will take it to third party audi specialist.
    The one thing i was disappointed about is that it was not possible to access the steering assistance to change the values. That feature apparently removed in 2007!! whyyyyyy. I hate u for doing that VW group. I know people with GTIs who replaced the steering rack motor with an older one to get the feature back. So now il have to depend on the springs, sway bars and some negative camber to improve steering feel.
