VCDS with the 8V
jojo Apr 21, 2014
  1. jojo
    29,001
    3,657
    Please note that using VCDS on your Audi is at your own risk, ASN takes no responsibility for an damage caused by the personal use of VCDS on your own, or other members vehicles following the guides as published in the threads below.
    Take note, please open and read the thread below first before using VCDS on your Audi, if you have no experience of using it before.
    http://www.audi-sport.net/vb/new-a3-s3-8v-chassis/206994-vcds-mods-warning.html
    8V VCDS discussions in the thread below
    http://www.audi-sport.net/vb/new-a3-s3-8v-chassis/207419-vcds-discussions.html
    8V specific VCDS mods in the thread below
    http://www.audi-sport.net/vb/new-a3-s3-8v-chassis/206515-8v-vcds-mods.html
    Alerix likes this.
  2. RobH_S3
    RobH_S3 Active Member
    440
    208
    43
    Can someone have a look through vagcom to see if they can turn off the exhaust sound in the speakers assuming it has it on the S3.
  3. jojo
    29,001
    3,657
    Rob2k68 and Liquidfusion-S3 like this.
  4. Bandicoot51
    Bandicoot51 Active Member
    134
    55
    Woah there is so much which is adjustable! Was thinking of turning off the headlight sprayers just the other day, ill have to have a good look at this code and figure out what can be done
  5. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,083
    10,767
    Nice list - thanks !!
    Auto front PDC activation is a good one to add.
  6. Bandicoot51
    134
    55
    whats that stand for?
  7. Rob2k68
    7,083
    10,767
    Park Distance Censor ;o)
  8. Darren92
    Darren92 Well-Known Member
    2,085
    539
    Park Distance Control ;)
    mr gee and Rob2k68 like this.
  9. Bandicoot51
    134
    55
    That would be great to have
  10. Rob2k68
    7,083
    10,767
    Enable automatic activation of parking tones when approaching obstacle
    Select STG 10 (parking aid)
    STG access authorization - Select function 16
    Enter access code 71679
    STG coding -> Select function 07
    Select Byte 3
    Enable Bit 4
    It kicks in at around 2ft (0.6m) away from the obstacle in front so won't annoy when in slow moving traffic. It won't change to the graphical display you have to listen out for it. One of the more useful VCDS mods in my opinion.
  11. Bandicoot51
    134
    55
    Thats a great touch that it doesn't pop up the graphic, i prefer listening to the beeps anyway
  12. jojo
    29,001
    3,657
    Does this mean the actual sensors are permanently on, or does the car know you are parking, like being in 1st gear and at certain speed under 15kph for instance?
  13. Bandicoot51
    134
    55
  14. Rob2k68
    7,083
    10,767
    It is a good Q and one I can't honestly answer - it would make sense if there was a gear/speed factor taken into account.
  15. jojo
    29,001
    3,657
    You need to test it out, drive @20mph in 2nd gear and get someone to walk out in front of it, see if it beeps?* :laugh:
    *Try tailgating a mate @20+ like 1ft away and see if it beeps.
    Rob2k68 likes this.
  16. lucas-suisse
    lucas-suisse Active Member
    214
    100
    43
    Just tested "Fan Speed in Auto Mod" on my S3 and it does not work...
    Does someone else tested it with success ?
  17. Rob2k68
    7,083
    10,767
    Tried that some time ago with no luck - it was quite good on the Leon I had.
    lucas-suisse likes this.
  18. jungle650
    jungle650 Well-Known Member TeamMisano Gold Supporter Audi S3 quattro DSG
    591
    1,027
    93
    Hi Guys
    Has anyone completed any VCDS adaptions on later 2015 cars??
    Are these locked down differently from earler 13/14 cars?? Failed to do simple things such as Temp gauge mods etc
    Also does MMI specification / lack of Tech packs / Sat Nav etc have any influence on what can / cant be modded- ie Alarm sounds / Wipers etc etc.
    Thx
  19. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,260
    2,660
    Only adaptation I have had an issue with on a 2015 car is the wiper service menu activation. All else seems to work so far.
  20. Darren92
    2,085
    539
    Main issue on the newest model (MY15/16) is that Rosstech may not have compiled a label file for any new revisions of hardware. Everything else coding wise is usually the same, you'll just have to wait for VCDS update until they make label files for the newer controllers.
    PhillW likes this.
  21. jungle650
    591
    1,027
    93
    Ok thx. I guess will have to try again after an update then. Could not get anything to work on a 2015 Oct car. Thx
  22. DJAlix
    3,260
    2,660
    Just done some checking and using controller 09 as an example:
    2013 = Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA - BCM MQBAB H H14 0112
    2014 = Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA - BCM MQBAB H H14 0112
    2015 = Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ - BCM MQBAB H H18 0137
  23. jungle650
    591
    1,027
    93
    Ok thx , so am I right in thinking that things are a little different on the very latest cars? Or will a VCDS update eliminate these issues?
  24. DJAlix
    3,260
    2,660
    A VCDS update might resolve the issues but in the past modules with different part numbers often support a reduced or enhanced feature set, if that makes sense, so it might in fact turn out that the "feature" is no longer possible in the newer hardware.
    There are what I call "coding conditions" to consider also. Some Adaptations and or Codings only work when the following conditions are met:
    • Ignition in first position and doors closed
    • Ignition in first position and doors locked
    • Engine running and doors closed
    • Engine running and doors locked
    • Insert further combinations here...
    • MMI Unit is Reset following coding
  25. jungle650
    591
    1,027
    93
    Thx DJAlix ...Wow i had no idea there were also coding conditions as well: Doors closed open - engine on / off etc etc.
    So many factors , are these noted where each of these play a part, ie mod will not work if condition XXX is not met.?
    Thank you as always for your wisdom.
    Jungle
  26. DJAlix
    3,260
    2,660
    Never really seen any specific notes around "conditions" for the 8V to be honest, just suggestions from RossTech and testing by myself. All the mods I post up are completed with the engine running unless otherwise stated as my VCDS and VCP testing sessions tend to go on for a long time and I have no access to mains power while in the car.
  27. DJAlix
    3,260
    2,660
    ...and speak of the devil, VCDS 15.7.2 has been released :)
  28. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    I thought I'd missed a few updates then ! Lol
    You mean 15.7.2
    DJAlix likes this.
  29. DJAlix
    3,260
    2,660
    Doh! Edited lol
