vcds total cost?? i did try vcds forum
epox Feb 10, 2013
  1. epox
    epox Active Member
    772
    74
    ok here goes, sorry if this is somewhere else.
    downloaded vcds lite, got a cheep cable from ebay seems to work.
    now im looking at getting a license for this from ross tech, what i want to know do i have to buy a ross tech cabe as well as a license to get full use??
    so would it be $99 plus the cost of one of thier cables
    or
    would it be $99 plus using the cheep ebay cable.
    cheers mark
    ps its to be used on a 2003 s3
  2. <tuffty/>
    21,008
    3,770
    vcds lite is 99 bucks + cost of any cable... vcds lite is licenced to the laptop you install it on... full fat vcds is 230ish quid (iirc) but the cable acts as a dongle and can be used on any machine with vcds installed... I regularly swap between my netbook and laptop...
  3. rhys1210
    rhys1210 Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    168
    23
    its $99 plus the cost of the ebay cable.
    if you want to get the full hex can usb cable they are $349 (this it to do mk5/6 stuff)
  4. epox
    epox Active Member
    772
    74
    thanks gents
  5. Scullies
    Scullies Well-Known Member
    1,543
    657
    You can buy the lite version first and use that until you want to upgrade to full version, then you will get a $99 discount off the full price.
  6. N8
    17,163
    718
    Why not buy it from NHN?
  7. JudderMan
    JudderMan Well-Known Member
    1,004
    164
    Is VCDS Lite any good though? I had a few codes yesterday, now sorted, and just Googled/Ross Tech'd the codes. I can't wipe the codes but I have a VAG mechanic friend that does it but I like to tinker with my own car so I like to know what's going on. I can't see the benefit of paying $99 for a license. Even if Ross Tech pulled the pages of their site that deciphered the codes, there are plenty of ASN threads and other VAG forums that explain what they are.
  8. slowcoach3
    slowcoach3 Active Member
    835
    105
    43
    I have a basic download of vcds lite, its ok but thats it! With the free copy you can check and clear some codes but not check every block on the car, you can also only log blocks 1-20 so you can log maf but not boost, fuel trims etc. For a 7 quid ebay cable its better than nothing but 99 bucks buys you a lot more and 250 gets you more again. Personally I'd recommend a registered copy of lite....
  9. devil_vas
    devil_vas Member
    32
    i bought my VCDS cable HEX + CAN with soft VCDS release 11.11.4 (inkl. Golf VI, R8, Bentley Cont. and etc.) for £80 qiuck from BG ;) if someone have interest i can send to uk.
