VCDS Security code?
esxb May 5, 2011
  1. esxb
    esxb New Member
    Hi
    I recently retrofitted a bluetooth module to my car (2007 A3 8P) and also RNS-E.
    Today I had a go a recoding using VCDS but came accross a problem, I selected the modules for Navigation and Telephone in the CAN BUS tick list, then went to code the modules, the Navigation module was fine to code but when I went to do the Telephone module I cant access coding?? I have to first enter a security code? I havnt a clue where to get this code a search on tinternet says that often VCDS will tell you a code to use when you click the box to enter it but this is not the case??
    Any help would be great as the RNS-E still does not recognise telephone/bluetooth?!
    Thanks in advnace
  2. a8 tech back
    a8 tech back Member
    198
  3. esxb
    esxb New Member
    Thanks for the reply, Ive checked the wiring and it all looks to be as it should as per the diagram..
    Im really stuck as loads of people have put bluetooth in and no one seems to have had to enter the security code before coding the 77-Telephone module?
    As far as I can make out I just need to enter the security code then it will allow me to code the module, does anyone know where I can get the security code from other than the dealers??
    Thanks in advance
  4. NHN
    29,561
    1,778
    Do you have an autoscan log?
    Do you have a screen shot of this request?
  5. a8 tech back
    a8 tech back Member
    198
    also have you coded gateway to recognise address 77 is installed and is the phone control unit the correct one
  6. esxb
    esxb New Member
    Below is a full scan I carried out showing any faults, I will try and get some screen shots later after work, im pulling my hair out over this one!!
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Thursday,05,May,2011,14:40:44:46862
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 2537 42 44 46 47 52 56 77
    VIN: WAUZZZ8P88A066432 Mileage: 69410km/43129miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status:OK 0000
    44-Steering Assist -- Status: OK0000
    46-Central Conv. -- Status: OK0000
    47-Sound System -- Status: OK0000
    52-Door Elect, Pass. -- Status:OK 0000
    56-Radio -- Status: Malfunction 1010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW:03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H42--- Serialnumber: AUX7Z0G8FN40FZ
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 74ECDE8E28E139BC
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW:1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    VCID: 73EEDD922DEF3E84
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AG HW:8P0 820 043 AG
    Component: KlimavollautomatH19 0420
    Revision: 184622 Serialnumber: 8P0820043AG
    VCID: 71E2D79A57F30C94
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW:8P0 907 279 K
    Component: Bordnetz-SG H542501
    Revision: 00H54000 Serial number: 00000007599821
    Coding: 01880F07A01410004F0000000000000000085E175C010000000000000000
    Shop #: WSC 06314 000 08192
    VCID: 458A534A33FBF034
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H010130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 N HW:8P0 959 655 N
    Component: Airbag 9.41 H01 4230
    Revision: 91H01423 Serialnumber: 003CR000AJE%
    Coding: 0071612
    VCID: 4D9A6B6AEB8B0874
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW:1K0 953 549 AH
    Component: J0527 0360070
    Coding: 0000012
    VCID: 78F4EABE34895DDC
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 981 K HW:8P0 920 981 K
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number:2248G001005607
    Coding: 0004428
    Shop #: WSC 00359 210 182332
    VCID: 4084425E2CD9D51C
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW:1K0 907 951
    Component: J533__Gateway H150180
    Revision: H15 Serial number: 1400K0782680E6
    Coding: E9801F065006020101
    VCID: 3064129E9C79459C
    2 Faults Found
    01304 - Radio
    004 - No Signal/Communication -Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 69390 km
    Time Indication: 0
    Date: 2011.05.04
    Time: 13:12:27
    01044 - Control ModuleIncorrectly Coded
    000 - - -Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 65724 km
    Time Indication: 0
    Date: 2011.02.21
    Time: 15:06:23
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H20001 Serialnumber: AUX7Z0G8FN40FZ
    Shop #: WSC 00000 000 00000
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 S HW:8P0 035 192 S
    Component: RNS-E HIGH EU H77X---
    Revision: 04S Serial number: AUZBZ7J4111008
    Coding: 0205151
    Shop #: WSC 00250 211 85023
    VCID: 3F8641A25127AAE4
    4 Faults Found
    00858 - Connection; Radio ZFOutput to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 202
    Mileage: 32296 km
    Time Indication: 0
    Date: 2010.06.24
    Time: 17:17:16
    Freeze Frame:
    Mileage: 65720 km
    Count: 2102
    Clock: 15:05
    02454 - Microphone Unit (in FrontRoof Module) (R164)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 213
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 69390 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 31:63:63
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 69390 km
    Time Indication: 0
    Date: 2011.05.04
    Time: 13:30:42
    Address 42: Door Elect,Driver Labels:8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW:8P0 959 801 K
    Component: Tuer-SG H030040
    Coding: 0000560
    VCID: 438E4D523DCFCE04
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.079 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 366824867E1D6BAC
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980202002186D298505489AC637
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 0050003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW:8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serialnumber: 30659740304674
    VCID: 346C1E8E686179BC
    Address 52: Door Elect,Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW:8P0 959 802 K
    Coding: 0000560
    VCID: 448C4E4E38C1C93C
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205151
    4 Faults Found
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 202
    Mileage: 32296 km
    Time Indication: 0
    Date: 2010.06.24
    Time: 17:17:16
    Freeze Frame:
    Mileage: 65720 km
    Count: 2102
    Clock: 15:05
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 213
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 69390 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 31:63:63
    01044 - Control Module IncorrectlyCoded
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 69390 km
    Time Indication: 0
    Date: 2011.05.04
    Time: 13:30:42
    Address 77: Telephone Labels: None
    Part No SW: KTC 364 31P HW:KTC 364 31P
    Component: SWP:3.21.9 H240197
    Revision: 00000000 Serialnumber: 00000000000000
    Shop #: WSC 21977 142 74100
    VCID: 336E1D926D6F7E84
    End ---------------------------------------------------
  7. NHN
    29,561
    1,778
    That BT part no. doesnt look good for a start, you got any pics of the part?
  8. esxb
    esxb New Member
    I dont at the moment mate as im at work, which bit are you refering to??
    When others have fitted bluetooth is it simply a case of selecting telephone on the can bus list then going into module 77-Telephone and coding it??
  9. a8 tech back
    a8 tech back Member
    198
    is this oem bt for audi
    audi 8p p/n
    8P0 862 335 F
    8P0 862 335 M
    8P0 862 335 H
    8P0 862 335 K
    8P0 862 335 Q
    your p/n KTC 364 31P HW is a fiscon so no need to code it
    just encode and adapt rnse to add the bt function
    see here http://www.fiscon-mobile.eu/support/img/fiscon_audi_en.pdf
    RNS-E Address 56 0xxx?xx set it to 7 (for USA it has to become 6)
    The head unit need to have a software index of at least 350
    in addition Audi A3 8P Address 19 (CAN Gateway) Byte 03 Bit 7 Telephone
    In some cases Byte 05 Bit 2 Telephone
    Address 16 (Steering wheel) 02xxx 03xxx
  10. NHN
    29,561
    1,778
    Thats a fiscon unit.
    FISCON Handsfree Bluetooth - Basic-Plus - Audi, Seat [36431] - $448.95 : Kufatec USA, Inc., The #1 Supplier of OEM Volkswagen & Audi Retrofit Harnesses in the World
    Check the numbers of part no. against the part no. on kufa site.
    EDIT: Pipped to the post :p
  11. a8 tech back
    a8 tech back Member
    198
  12. esxb
    esxb New Member
    a8 tech/NHN,
    You are both legends! It is all sorted now, thanks very much for your help :)
    Oh and apologies I didnt say it was a fiscon unit, i really should have mentioned that, doh!!
