VCDS question for B8.5
Liquidfusion-S3 Mar 26, 2014
  1. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,475
    726
    So just picked up a VCDS cable from NHN and on with my tweaks... first one is Disable seat belt chime but I'm a bit confused to whether anyone else run into the same prompt? Not sure what to do:
    Disable Seatbelt Chime
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
      File size:
      22.1 KB
      380
    deanr123 likes this.
  2. Audi Toby
    Audi Toby 2016 S3 Saloon
    256
    51
    Hit yes. It is just filling in the workshop number by default so dealers can't see it's been re programmed.
    Liquidfusion-S3 likes this.
  3. Audi Toby
    256
    51
    Much like it will automatically give you the correct security access codes for each module when you're coding/adapting.
  4. Liquidfusion-S3
    1,475
    726
    Ah ok thanks! :)
  5. Liquidfusion-S3
    1,475
    726
    Sorry last one, I don't quite get how to do this:
    Enable Release Parking Brake without putting foot on Brake
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    ________________________________________
    Enable Release Parking Brake without putting seatbelt
    [Adaptation - 10] -> Channel 7 Set to 0
    (I don't see a channel 4 or 7)
  6. Audi Toby
    256
    51
    I would be lying if I said I knew. Yours is the B8.5, mine is the B8 so it has a different menu there. I discovered most of my coding by myself, I recommend making a 'module map' in other words write down what the adaptation setting and long coding is so that whatever you play around with you can always just put it back to the way it was!
  7. Audi Toby
    256
    51
    Two seconds, I'll go and screenshot my channel 53 to see what I've changed. Might be helpful? In the meantime, check this out ^^ as this is the updated VCDS list for the B8.5.
  8. Audi Toby
    256
    51
  9. allanmb
    allanmb Well-Known Member Team Tango Audi S3 quattro
    720
    516
    93
    This is the one I can't get working on B8.5 either :( Mind you, I don't get the correct security access code so you seem to be getting a little further than I
  10. Parklife
    Parklife Active Member
    122
    30
    I got it working after talking with Ross tech, but can't remember how exactly!!! Just checked on mine for some of the settings, but not obvious what I changed.
    (1) Driver out apply
    (2) Driver out apply - evaluation of brake pedal
    (4) Driver out apply - evaluation of seat belt
    All these are set to not activated on mine. Let me know what yours are and if they are different suggest to change, otherwise I'll take another look and see if I can work it out.
  11. Parklife
    122
    30
    Have you tried 78713?
  12. allanmb
    720
    516
    93
    Just tried that and it said I had access. I then tried changing some values and it said I required security access. Also, my options are different to those above. I was trying "Seat belt buckle detection" and "Manual release". I think it might be because I am running a very old version of VCDS :(
  13. Parklife
    122
    30
    Probably worth upgrading to the latest version.....I was advised to upgrade to the beta version when I was having issues.
  14. allanmb
    720
    516
    93
    I'm not sure if I can upgrade. I bought the cable from eBay thinking it was genuine but I have a feeling it isn't :-( it cost enough!
  15. Audi Toby
    256
    51
    Genuine cables don't vary much in prices so if it was anything less than £250 it's a definite counterfeit.
  16. allanmb
    720
    516
    93
    It was £150 around 4 years ago :(
  17. Audi Toby
    256
    51
    Maybe it's real then? If you want give Ross-Tech a call and they'll tell you. If not speak to 'NHN' or 'Sandra' on here, they'll be able to help with it and maybe point you towards updating it.
  18. Liquidfusion-S3
    1,475
    726
    I tried this but it doesn't work,
    (1) Driver out apply (was activated, disabled but still no change)
    (2) Driver out apply - evaluation of brake pedal (already disabled)
    (4) Driver out apply - evaluation of seat belt (already disabled)
  19. Audi Toby
    256
    51
    Can "parklife" make a module map (application, controller map, channel 53, adaptation and enter the security code) to directly compare with your module map "Liquidfusion" that's the easiest way to see the differences in the adaptations!
  20. Parklife
    122
    30
    Here you go - one thing to note I have only activated Enable Release Parking Brake without putting seatbelt
    ;SW:8K0-907-801-M HW:8K0-907-801-J --- Parking Brake
    ;Component:EPB-4 H01 0004 Coding:
    ;EV_ParkiBrake 1028
    ;Thursday 27
    ;VCDS Version: Beta 12.10.7 (x64) Data version: 20130802
    ;VCID: 397D72B4B89FDAD68A3-806C
    (1)-Activating and deactivating all development messages-development message S100 not active
    (2)-Activating and deactivating all development messages-development message S101 not active
    (3)-Activating and deactivating all development messages-development message S102 not active
    (4)-Activating and deactivating all development messages-development message ECU specific 01 / (02) not active
    (5)-Activating and deactivating all development messages-XCP ECU specific not active
    (6)-Activating and deactivating all development messages-development message ECU specific 03 to 10 not active
    (1)-Automatic parking brake-automatic activated
    (2)-Automatic parking brake-Man.trans. not activated
    Automatic parking brake for selector lever position P not activated
    Production mode not activated
    Roller test bench mode; functional not activated
    (1)-Transport mode-Status Transportmodus not activated
    (2)-Transport mode-Status Automatische Aktivierung Transportmodus activated
    Auto Apply due to engine stall activated
    Auto Apply due to switch failure not activated
    Drive Away Assist activated
    Drive Away Assist Sensitivity normal
    Drive_away_assist_without_gas activated
    (1)-Driver Out Apply- activated
    (2)-Driver Out Apply-Evaluation of brake pedal not activated
    (3)-Driver Out Apply-Velocity for Reset 1.0 km/h
    (4)-Driver Out Apply-Evaluation of seatbelt not activated
    Emergency Braking front and rear
    Emergency Braking intensity 6
    Manual release with button and brake pedal depressed
    RDL not activated
    (1)-Reduced Clampforce-Reduced Clampforce Automatic Transmission not activated
    (2)-Reduced Clampforce-Reduced Clampforce Manual Transmission activated
    (3)-Reduced Clampforce-Reduced Clampforce Inclination Treshold 0%
    (4)-Reduced Clampforce-Reduced tensioning force during start/stop activated
    Seat belt buckle detection not activated
    Shift P to EPB not activated
    VIN Check activated
    Audi Toby likes this.
  21. Audi Toby
    256
    51
    Awesome. @Liquidfusion Just directly compare this with yours and just have a play around.
  22. Liquidfusion-S3
    1,475
    726
    Crikey! lol:scared2:
  23. Parklife
    122
    30
    Post it up here and we will help :)
  24. Audi Toby
    256
    51
  25. bpodnar
    bpodnar New Member
    What RDL channel is used for?
