VCDS Mod list ? Do we have one ?
Anthony566 Feb 24, 2014
  1. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Hi do we have a VCDS Mod list like this one ?
    Enable Hidden menu in MMI
    Adjust bluetooth[​IMG] microphone sensitivity
    Change MMI 3G splashscreen
    Disable After-wipe of windscreen[​IMG] wipers
    Disable amber corner lights
    Disable amber side markers
    Disable Key warning (keyless models)
    Disable LED 'wink' on turn signal - pre-facelift
    Disable LED 'wink' on turn signal - facelift
    Disable bulb error message with LED reverse lights installed
    Disable "Lights are on" warning
    Disable NAV & Phone warning messages while entering data at speed
    Disable Seatbelt[​IMG] Chime
    Disable soundaktuator (speaker on face lifts)
    Enable Adaptive brake lights
    Enable Ambient Interior Lighting Control
    Enable Optic rear parking for cars without front parking sensors
    Enable Automatic Gear selection shown in DIS
    Enable Automatic Hill Hold Assist[​IMG] 'lite'
    Enable Auxiliary ventilation
    Enable Battery meter *does not appear to work on facelift cars with MMI 3G+ HDD Navigation*
    Enable DIS with Efficiency Program
    Enable Double Disarm Beep
    Enable Drivers Memory Seat
    Enable DRL Selectable via MMI
    Enable DRL
    Enable Audi Drive Select without the buttons
    Enable Euro parking lights that turn on signal at night
    Enable interior lighting option
    Enable fog lamp to come on for the same side as that turn signal
    Enable Front Turn Signals as Parking lights
    Enable Gauge Test/Needle Sweep
    Enable Import CDs to MMI's HD
    Enable Independent Fogs control with high beams
    Enable Lap Timer
    Enable LEDs remain bright for parking lights
    Enable Rear Tail Lights on with DRLs
    Enable Release Parking Brake without putting foot on Brake
    Enable Release Parking Brake without putting seatbelt
    Enable Remote Operation windows&sunroof
    Enable Reverse mirror tilt
    Enable Speed through MMI
    Enable ‘Tourist’ Mode – Headlight[​IMG] Convertor (MMI 2G)
    Enable TPMS (Tyre[​IMG] Pressure Monitoring System)
    Enable Video in Motion on MMI
    Set Audi parking system - Switch OFF Speed
    Set Custom ADS settings
    Set Headlight washer - cycles
    Set Headlight washer - duration
    Adjust Consumption in DIS
    Adjust LED Brightness
    Change Language
    Activate SDS for cabriolet
    Change fuel tank[​IMG] characteristics
    To increase radio play time after car is turned off
    Audi A4/S4/A5/S5 B8
    VCDS (VAG-COM) codes
    Enable Hidden menu in MMI 3G
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6
    change 0 to 1
    To access the hidden menu, hold down car and setup together for 5 seconds
    Use this hidden menu at your own risk.
    Enable Hidden menu in MMI 2G
    [07 - Control Head]
    [Adaptation - 10] -> Channel 8 -> Change 0 to 1
    Use this hidden menu at your own risk. Caution: Keep away from the "Bootloader"
    ________________________________________
    Adjust bluetooth microphone sensitivity
    Hidden menu
    Diagnose
    Settings
    Mic sensiblity - choose -6db/0db/+6db
    Change MMI 3G splashscreen...
    Enable through the "hidden menu":
    - navigate to 'car/carcodingvehicle'
    - choose the model of choice in 'configuration line'
    - select 'Update Splashscreen'
    - restart MMI
    Disable After-wipe of windscreen wipers
    [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 7 set to 0 (Uncheck)
    Disable LED 'wink' on turn signal - pre facelift
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3 (Heading Wink Brightness)
    Default Value is 26, Setting value to 88 (Makes it identical to normal brightness)
    CREE LED reverse lights with RESISTOR and I STILL get a bulb out warning?
    Disable "Lights are on" Warning
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
    Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    Disable Seatbelt Chime
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
    To mute the Soundaktuator
    A9 Structure Borne Sound
    Adaptation 10
    At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
    Enter a value in the proper box (0% = mute )
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    Enable Optical rear parking for cars without front parking sensors
    [10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    Enable Automatic Hill Hold Assist ‘lite’*only works on certain abs[​IMG] modules - see below link*
    [03 - ABS brakes][Security Access - 16] (Enter code presented by program)
    [Coding – 07] -> Long Coding Helper -> Byte 1
    Bit 6 set to 1 to enable hill hold assist.
    http://www.audienthusiasts.com/VagComABS.html
    [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
    Bit 1 – Set to 1
    [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    For MMI equipped cars
    [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
    [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
    Reset MMI
    or
    [56 - Radio] -> Adaption -> Channel 39, add 16 to your value
    For symphony, Chorus and Concert
    Select module 56 - Radio
    Select “Adaptation – 10
    Select channel 39
    Add 16 to the present value
    "test"
    "save"
    “Done, Go Back” and "Close Controller
    Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
    [17 - Instruments] [Adaptation - 10] -> Channel 77
    change 0 to 255
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    ensure Module 46, Byte 1, Bit 2 is ticked. This activates the alarm audible notification option
    36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
    Seat memory will be there however greyed out in MMI
    Press and hold down unlock button on key fob for 5 seconds for the windows to come down
    Press and hold down lock button on key fob for 5 seconds for the windows to go back up
    In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
    [09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
    Bit 5 set to 1
    Enable DRL
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 1 = DRL via Front Side markers
    Bit 2 = DRL via High Beams
    Bit 3 = DRL via Fogs
    Bit 4 = DRL via LEDs
    Bit 6 = DRL via Side markers
    Bit 7 = DRL via Tail lights
    By far the best guide is here - http://www.audienthusiasts.com/Project_ADS.html
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 0 - Set to 1
    Enable interior lighting option for pre-facelift
    MMI Basic (Symphony/Concert radio) - (NON-MMI - 2G/3G):
    Code:
    [56 - Radio]
    [Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
    MMI high (2G):
    Code: Enable the Interior lighting (extended) MMI item:
    [07 - Control Head]
    [Adaptation - 10] -> Channel 1 add 2 to the existing value
    MMI high (2G hidden menu as alternative)
    If you choose to use the 2G hidden menu you will find the setting using the following:
    DIAG SETTINGS -> APK 0x01, 0x0B, 0x0C -> Interior lighting (extended)
    MMI 3G
    This can only be activated through hidden menu
    Enter hidden menu - choose car - choose carmenuoperation - select interior light - set to 5 to allow adjustment whist moving - press return - select cardevicelist - choose interior light and press to fill box in - press return
    Reset MMI (press setup, scroll wheel and top right button next to scroll wheel at the same time)
    Option will show in MMI
    Enable interior lighting for facelift cars
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 16
    Bit 6 - Interior/Ambience Lighting Adaptation active
    Hidden menu - [carbusassignment] - Interior Light to [CAN Komfort 1/9]"
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Check the box or change :Bit 0 set to 1
    Bit 0- Check the box or change :Bit 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change:
    Bit 6 - Check the box or change :Bit 0 set to 1
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
    Enable Headlights on all the time
    Bit 5 - Check the box or change (Bit 5 Set to 1)
    [Hidden menu]
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Enable Lap Timer
    Bit 3 - Check the box for "Lap Timer active"
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    Bit 7 - DRL's via Tail Lets Active (1 = Active)
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    [Adaptation - 10] -> Channel 7 Set to 0
    [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
    Bit 3 and Bit 2 set to 1
    [56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
    Does not work if NAV equiped
    Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
    [09-Central Elect]
    [Coding – 07]
    [Long Coding Helper] - Byte 4, Bit 6 = 1
    Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
    [55-Xenon Range]
    [Adaptation – 10]
    [Channel 10] - 0 = Disable 1 = Enable
    Press ‘Test’ and then ‘Save’
    Enables the Headlight Convertor MMI item under the CAR button.
    Restart MMI to see changes.
    Enable TPMS
    * only works with certain ABS modules - see below link *
    Enable Video in motion on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    Set ADS to specific preset Comfort, Auto, Dynamic or Individual
    [09 – Cent. Elect.][Security Access - 16]
    Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
    [Adaptation - 10] -> Channel 64
    [Adaptation - 10] -> Channel 65
    [Adaptation - 10] -> Channel 66
    *Note all four channels needs to be set to the same value.
    Set Headlight washer - Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Set Headlight washer - Cycles
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 26
    change to e.g. 10
    [17 - Instruments]
    change 100 to xxx (see samples below)
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95,83)
    Channel 3 will be changed from 100 to 96
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 03
    Set between 5 and 100 (5 being lowest and 100 brightest)
    Select language in DIS:
    17 - Instruments
    Byte 8 -> Bit 0-4 - ->
    Select the language.
    Activate SDS for cabriolet:
    5F–Information Electr.
    Change Byte 15 – Bit 0 to 1
    Change Byte 16 – Bit 0 to 0
    Change fuel-tank charisterics:
    17 - Instruments
    Adaption - change channels 30 and 33
    To increase radio play time after car is turned off:
    In the Hidden Menu:
    MMI 2G:
    "MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
    MMI 3G:
    From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes.
    ruairi83 and voorhees like this.
  2. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,687
    550
    Great find!
  3. Archies
    Archies Active Member VCDS Map User
    278
    87
    Brilliant that is,
    Archie...
  4. Kjaer85
    Kjaer85 Member
    45
    Somebody make this a sticky!!! I'm gonna sit in the car with my laptop the next couple of days:)
  5. Big-Boy
    Big-Boy New Member
  6. Big-Boy
    Big-Boy New Member
  7. Big-Boy
    Big-Boy New Member
    Not bad, but this is all copy-paste from other websites or forums
    There are places where this is much better explained
    a6_chris likes this.
  8. Anthony566
    732
    111
    43
    And your point is re the copy and past ??? I don't think anyone is claiming ownership of this the question was do we have a list like this one ??
  9. Big-Boy
    Big-Boy New Member
    Here's a better list
    VCDS
    This is the best - with a list of all cars
    stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - Codierungen - VCDS Codierungen, Webdesign
    On German language but Chrome with translator
    Good luck
    PS: This does not work on all models
    The control units with graphical display support are :
    8K0919475A
    8K0919475C
    8K0919475E
    8K0919475G
    8K0919475P (acording to etka, only for Q5 and A5 Sportback)
    8K0919475J
    8K0919475R
    The PR code for parking front and rear is 7X4,7X8
    Non graphic support (only back parking sensors):
    8K0919475
    8K0919475B
    8K0919475D
    8K0919475F
    8K0919475S (acording to etka, only for Q5 and A5 Sportback)
    8K0919475H
    8K0919475Q
  10. Big-Boy
    Big-Boy New Member
    With this nothing you can. Where is the explanation for Instructions 2G or Instructions 3G:
    I miss a lot of explanation and this:
    Manually Decoding Your Security Code or Automatic VIM Generator
    When you copy an instructions - copy a complete instructions not just one part
