VCDS Login codes
richy Dec 3, 2010
  1. richy
    richy Member
    892
    help im totally lost.. i need a login code to access the modules..
    i need to access the central electrics and change the coming home lights which are currently fog lights.. and i want to change them to the headlights
    the car is a Audi B7 with the HID Conversion with the Ballists etc
    the scan is as follows.
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: HIDDEN Mileage:
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 JD HW: 03G 906 016 JD
    Component: R4 2,0L EDC G000SG 9643
    Revision: --H05--- Serial number: XXXXXXXXXXXXXX
    Coding: 0000072
    Shop #: WSC 00661 210 81342
    VCID: 6ED6499700EB
    1 Fault Found:
    005512 - Engine Mount Solenoid Valves (N144/N145): Open Circuit
    P1588 - 000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 1
    Mileage: 119723 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    Shop #: WSC 06325 000 00000
    VCID: 2C52839FF677
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CD2439F36F7
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 01001
    Shop #: WSC 06325
    VCID: 3D74BEDB1D0D
    1 Fault Found:
    01504 - Bulb for License-Plate Light (X)
    30-00 - Open or Short to Plus
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H14 4230
    Revision: 91H14423 Serial number: 0036M0G9NDKQ
    Coding: 0031612
    VCID: 3B70B0C30319
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 87
    Reset counter: 39
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 R
    Component: Lenksáulenmodul 0701
    Coding: 03041
    Shop #: WSC 00661
    VCID: 428ECD2764F3
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 982 M HW: 8E0 920 982 M
    Component: KOMBI+WFS 4 H10 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0006418
    Shop #: WSC 00654 210 60455
    VCID: 387AAFCF322F
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H74 0600
    Revision: 04S Serial number: AUZBZ7G1142023
    Coding: 0309717
    VCID: 326E9DE7D453
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 134
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:01:14
    Freeze Frame:
    Voltage: 12.20 V
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 134
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:00:36
    Freeze Frame:
    Voltage: 12.20 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD0C083B3F9
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CQ
    Component: Komfortgerát T3B 4236
    Coding: 06895
    Shop #: WSC 06325
    VCID: 820E8D27A473
    Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    4 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0309717
    VCID: 326E9DE7D453
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 134
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:01:14
    Freeze Frame:
    Voltage: 12.20 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 134
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:00:36
    Freeze Frame:
    Voltage: 12.20 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0550
    Revision: 00000000 Serial number: 00000005057684
    Coding: 0011822
    Shop #: WSC 00654 210 91815
    VCID: 4686D13748DB
    End ---------------------------------------------------------------------
    ive deleted the VIN for obvious reasons.
    could you help me with the login code and obviously how you obtained it for me.. as ideally i dont want to be on here everytime it requires login...
    thank you.
    ive been on the ross tech website.. looked in the manual etc.. but doesnt tell you where to look or how to obtain it other than look in the serivce manual which the owner doesnt have...
    thank you in advance.. your help is appriciated.
  2. Sebastian
    Sebastian Member
    286
    Audi never intended the use of HIDs which are technically illegal as you probably know, so they have not included a setting like you want it in the control module software. No login is going to change this.
  3. richy
    richy Member
    892
    Sebastian,
    Thank you for the reply appreciate it will let my friend know.
    Could you tell me how to get the login codes from the original information supplied? Ideally explain what information gave u the login code. Not just for the cntrl electrics but for any module its a pain when someone comes over and a login as needed.
    Teach me how to fish and I can feed myself for a lifetime sorta question haha.
  4. Sebastian
    Sebastian Member
    286
    Again, there is no login for the stuff you are looking for. Just because the login function is there doesn't mean it is actually used, especially not for random modifications like you are looking for. If a login is necessary VCDS will usually tell you and the proper login will show once you access the login function. In this case that doesn't happen because there is no login necessary to perform all available functions on this control module.
    Ross-Tech: VCDS Tour: Login
  5. richy
    richy Member
    892
    Ok thank you for your help.
