VCDS logging suggestions on what to log.
Westy Feb 2, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    Right I've just spent £50 on silicone hose, I'm going to get to the bottom of this problem :banghead:
    After i've finished with this lot there will only be a few hoses left. The upper and lower boost hoses will get done when I get my FMIC. Bloody ***** rubber hoses!
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Good to see you battling on through dude. It'll be worth it in the end - some things are a pain, and are expensive, but keep your eye on the prize....
  3. Westy
    17,443
    1,105
    It seems like every bit I replace, my fluttering/boost leak gets worse! Sodding thing. I've got a load of 8mm and 13mm hose so I can do all the charcoal canister hose and all the ***** round the inlet mani too.
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Good luck Westle, I know how irritating this type of thing can be.
  5. Westy
    17,443
    1,105
    Cheers mate. I should have all the gear by Thursday and I'm planning another later night mechanics session on Thursday to get it all fitted. I'll keep this thread updated and once the issue has gone I'll get some fresh logs done.
  6. Welly
    10,696
    130
  7. Westy
    17,443
    1,105
    Will I be ok running with a boost leak for the next few days? The car seems to be running ok until i'm on boost then it just gets very noisey with air rushing about!
  8. Welly
    10,696
    130
    Yeah, it won't do any lasting damage really. Don't drive it hard obviously though.
  9. Westy
    17,443
    1,105
    Thanks, I've been changing gears at 2K revs to stay off boost as much as possible but I jus hate driving the damn thing when its not running correctly.
  10. Westy
    17,443
    1,105
    I think i've found a problem! I dont think its the cause of the fluttering but I think it is my main boost leak. Yesterday I noticed that a jubalee clip had been rubbing on the boost hose that runs from the charge pipe into the drivers side SMIC. This clip has been there since the summer when I simplified my breather hoses and fitted my catch can. Last night a strapped up the hose with tape where it had been rubbing and today the rushing air noises has gone.
    I have some upper and lower boost hoses on order so I hope they arrive before the weekend.
  11. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Well done Westle, lets hope this is the cause of your problem.
  12. Westy
    17,443
    1,105
    Thanks mate. I've got enough silicone hose on order to replace the remaining boost hoses so I'm hoping the car will be back to its best again. The clip causing the problem was one thats holding in the one way valve for the brake servo. It was rubbing against the boost hose and had picked away at the outer rubber. The boost leak must have been getting slowly worse since the summer. I've order 2 90 bends to go around the boost hose so this should ensure that any clips are away from the new hose when it's on.
  13. Welly
    10,696
    130
    Sounds likely mate - leaks will put everything out, both on boost and idle..
    Fingers crossed dude.
  14. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Nice one Westle, hope it sorts it mate.
  15. Westy
    17,443
    1,105
    I've got a RR day booked with S3 Baby to go to Bills on 19th March, so whatever I dont pick up before then I'm sure Bill will find.
  16. Welly
    10,696
    130
    See you both there! lol
  17. Westy
    17,443
    1,105
    lol. Yeah if you and Paul can get there too it would be nice to finally meet you both.
  18. Welly
    10,696
    130
    It's Saturday dude - Bill's is standard MO. lol.
  19. finesse
    finesse Active Member
    2,805
    Cool! 19th March, can I tag along for a rolling road and lumpy idle diagnosis? :) :)
  20. Westy
    17,443
    1,105
    Cant see why not mate. Let me confirm with S3 Baby and Bill first.
  21. Westy
    17,443
    1,105
    Ok the tape I put round the possible boost leak didn't last long! Noise and power loss were back last night. Luckily the postman had been this morning and delivered my upper and lower boost hoses. I'm also hoping to get all my othe silicone bits later today too so tonight i'll be getting it all on.
    Will report back in the morning ;)
  22. Westy
    17,443
    1,105
    Ok, last night I fitted my intercooler hoses. 1 from charge pipe to drivers side and 1 from passenger side to throttle body. This morning I still have the boost leak!
    I am going to open a complaint with my eBay seller of the forge turbo hose which still hasn't arrived and they have ignored my emails. Tomorrow morning i will remove the existing red turbo hose again ang check it all over again.
    I'm running out of hoses to replace and I still cant pin point the leak. If replacing the red hose doesn't fix the leak then I'll be ordering a FMIC in the next week!
  23. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you thought about a smoke test or pressure test to find the leaks....may save you bashing your head against the wall...lol
    They are a pain, did you do the catch can?
  24. Westy
    17,443
    1,105
    I had a pressure test done 2 years ago and was told there were no leaks anywhere, not even in the SMICs. I've not tried a smoke test yet, think i might phone around and see who can do one locally.
    This has been a good exercise though because most of my old rubber hose has now been replaced with silicone ;)
    Catch can was all done last summer and I've checked over all the new oil hose I put in for the PCV system and it's all fine.
  25. Westy
    17,443
    1,105
    Just booked in for a smoke test next friday so I have 1 week to try and find the leak myself.
  26. finesse
    2,805
    EVAP can
    brake servo hose
    split in tip
    pipe from smic 1 to smic 2
    duff forge dv
    keep trying
  27. Westy
    17,443
    1,105
    The leak sounds like its drivers side so I'm thinking charge pipe or SMIC.
    Brake servo hose has been simplified since catch can install was done. I also have some silicone and a new one way valve to replace that hose.
    Tip is a 6 month old Autobahn TIP so I soubt that's a problem.
    The hose from 1 smic to another is a possibility and If the smoke test shows this as the fault, I'll be getting a FMIC
    I've checked the DV and it is working fine.
  28. Westy
    17,443
    1,105
    Well all my silicone turned up on Saturday so I set about fitting it. All i'm still waiting for is my Forge red charge pipe hose, which is 2 weeks late as the eBay seller has stitched me up!
    Anyway I found my leak! The red charge pipe hose had started coming away from the charge pipe and that's where boost was p*ssing out. I'm going to do some logging later today now the leak has gone but the car still feels down on power!
    Here is an engine diagram and what I've changed on my car. The green hoses are new and the orange components are new too.
    Original:
    Now:
    Key:
    1 - Fuel Tank Breather
    2 - Charcoal Filter
    3 - One Way Valve
    4 - Turbo
    5 - Wastgate Actuator
    6 - Diverter Valve
    7 - Brake Servo
    8 - One Way Valve
    9 - N75 Valve
    10 - MAF
    11 - Air Box
    12 - Oil Breather
    13 - N249 vacuum reservoir
    14 - SMIC
    15 - Fuel Pressure Regulator
    16 - Throttle Body
    17 - Inlet Manifold
    18 - Cranckcase Breather Valve
    19 - One Way Valve
    20 - N249
    21 - One Way Valve
    22 - SMIC
  29. Essflee
    Essflee Well-Known Member
    2,155
    67
    Cheers Westle, very handy diagram, thinking about doing all my pipes too...
    Nice one :)
  30. Westy
    17,443
    1,105
    No worries mate, I cant take credit for finding the diagram as Tuffty found it a while ago. I can only take credit for my updated diagram ;)
    I'm running out of things to change now to try and combat my lack of power! I think I'll have to wait for my visit to Bills and see what he finds.
  31. Westy
    17,443
    1,105
    Just did some logging and I'm still down on power. Only 191gs from the MAF (238ish bhp)
    Since fitting a new N75 I have no boost spike and the timing isn't being pulled any more that 3.8 degrees so that's much better.
  32. s3dave
    10,110
    736
    Have you reset the throttle body adaptions? maybe worth a shot...
  33. Westy
    17,443
    1,105
    Not since last year when I gave it a clean too. I'll give it a go later.
  34. Essflee
    2,155
    67
    What's the highest G/s you can recall having, isn't just the map is it ?
  35. Westy
    17,443
    1,105
    I've just done a throttle body alignment but it's made no difference, I cant get above 191gs. Once apon a time I recorded 204gs with the same map.
    Anyway I also found this in VCDS so I think it's time to address the CAT and sensors:
  36. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Does "Failed or Inomplete" inidicate a knackered sensor....?
  37. Westy
    17,443
    1,105
    Well the MOT centre said the Cat seems to be fine. I do get some funny voltage readings from the post cat sensor so I'm going to swap a sensor over from S3 Baby's car and see if that solves it.
  38. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Interesting, I'm sure when I was last logging my car I got the same results on the Catalytic Converter check and another box, but my car recently passed its MOT no problem :uhm:
    Another thing to check.....
  39. Westy
    17,443
    1,105
    If you wouldn't mind, could you check it when you get a chance? Cheers.
  40. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Yeah I'll give it a go tonight and post up.
