VCDS log, faults after mapping??
max69vk Oct 29, 2012
  1. max69vk
    max69vk Active Member
    862
    57
    Decided to scan the car tonight just to see what (if any differences) I could see after remapping with a Shark STS unit, I scanned the car & its come up with the faults below. Now I have no idea what these faults actually mean, is it pure co-incidence that these errors could have come up after mapping the ECU?
    Monday,29,October,2012,17:48:17:50725
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P18A105183 Mileage: 97960km/60869miles
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 4350
    Revision: --H52--- Serial number: AUX7Z0GNFN8003
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    VCID: 74ECA76E177D0AB835D
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    VCID: 73EEA47212730D802C7
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
    Component: KlimavollautomatH19 0420
    Revision: 213991 Serial number: 8P0820043AG
    Shop #: WSC 00000 000 00000
    VCID: 71E2AE7A686F3F90DEB
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007875894
    Coding: 01880F21B01410004F0000001900000000085E135C010002000000000000
    Shop #: WSC 06314 123 08192
    VCID: 458A2AAA0C67C330523
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 97770 km
    Time Indication: 0
    Date: 2012.10.12
    Time: 19:50:00
    Freeze Frame:
    ON
    Voltage: 12.10 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
    Component: Airbag 9.41 H01 4210
    Revision: 91H01421 Serial number: 003CP001MFC4
    Coding: 0071612
    VCID: 4B9E1C922A033540847
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002012
    VCID: 41823EBA184FEF106EB
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    00883 - Ignition Switch (D) Terminal S
    012 - Electrical Fault in Circuit - Intermittent
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: 224NG001102327
    Coding: 0004428
    Shop #: WSC 00088 210 88691
    VCID: 40843BBE1345E618615
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07B0704DE
    Coding: E9807F061002021103
    Shop #: WSC 00370 210 91464
    VCID: 30646B7EA3E57698915
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 97216 km
    Time Indication: 0
    Date: 2012.09.11
    Time: 11:31:17
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 65
    Mileage: 97770 km
    Time Indication: 0
    Date: 2012.10.12
    Time: 19:50:10
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20001 Serial number: AUX7Z0GNFN8003
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7LD209304
    Coding: 0205755
    Shop #: WSC 00141 211 17933
    VCID: 346C676E57FD4AB8F5D
    2 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 97216 km
    Time Indication: 0
    Date: 2012.09.11
    Time: 11:31:32
    Freeze Frame:
    Mileage: 97210 km
    Count: 1109
    Clock: 11:31
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 97216 km
    Time Indication: 0
    Date: 2012.09.11
    Time: 11:31:26
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0040
    Coding: 0000688
    Shop #: WSC 00294 210 62977
    VCID: 428031B61D49F408771
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.079 H08 1901
    Shop #: WSC 00493 128 61104
    VCID: 36685D66418158A8CB9
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980202002586D0985054C9FC637
    Shop #: WSC 06314 123 12345
    VCID: 438E34B20253FD007C7
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
    Component: AB2 SUBWOOFERBOXH06 0180
    Revision: 00005 Serial number: 30674752858380
    VCID: 356A5A6A5C8753B0C23
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Component: Tuer-SG H03 0050
    Coding: 0000688
    VCID: 448C37AE075DFA3845D
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205755
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 97216 km
    Time Indication: 0
    Date: 2012.09.11
    Time: 11:31:32
    Freeze Frame:
    Mileage: 97210 km
    Count: 1109
    Clock: 11:31
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 97216 km
    Time Indication: 0
    Date: 2012.09.11
    Time: 11:31:26
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    End ---------------------------------------------------------------------
  2. hades-
    9,481
    646
  3. max69vk
    862
    57
    Thanks for that Bez. I'm sure the 4th & 5th are due to me fitting an RNSE unit without using the updated antenna (although it didn't come up before), strangly I didn't have a single fault before the remap & clearing the faults doesn't appear to do anything as they just come straight back again :(
  4. max69vk
    862
    57
    So I've managed to get most of these issues sorted, some of them so stupid too like forgetting to put the DVD in the drive to register & forgetting I'd removed the BT unit to fit a newer one!
    Im still getting these two though:
    both of which have only appeared since the remap :(
  5. hades-
    9,481
    646
    call the company that did the remap and ask them if they have any idea as to why your geting them
    as the code does say
    Engine Control Module recently flashed or re-mapped
    [TABLE="class: gumax-row"]
    [TR]
    [TD="class: gumax-row-right"][h=2]01314 - Engine Control Module[/h][h=3]01314 - Engine Control Module: No Communications[/h][h=4]Possible Causes[/h]
    • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
    • Fault(s) stored in Engine Control Module
    • Engine Control Module recently flashed or re-mapped
    [h=4]Possible Solutions[/h]
    • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    [h=3]01314 - Engine Control Module: Check DTC Memory[/h][h=4]Possible Causes[/h]
    • Check Engine Control Module for Fault Codes
    [h=4]Special Notes[/h]
    • Engine Control Module stored a Code which influences other Control Modules Functionality.
    • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
    [/TD]
    [TD="class: gumax-row-left"][h=5]Categories[/h]
    [h=5]Meta[/h]
    [/TD]
    [/TR]
    [/TABLE]
  6. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Never seen this before and I scan all cars before and after remapping them. If it was done via the STS I would clear all faults then stick your stock map back on and do another scan to see if anything is flagged up. If not load the performance map back on and do the same.
  7. timontour
    timontour Member
    37
    Hi i'm getting exactly the same fault and my car was remapped about a month ago
    have you found out any info on this? i contacted the guy that mapped it and he's looking into it but he says he hasn't seen this fault before, as the ross tech site says it does seem to be to do with the map?
  8. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    Hello,
    this is quite normal and nothing to worry about, providing the faults clear. What happens is during the flashing process the ECU enters programming mode and cannot communicate wit the CAN gateway or other CAN modules. DTC is therefore stored. Once ECU is mapped faults should be cleared and not return.
    Rick
  9. timontour
    timontour Member
    37
    Hello Rick,
    i have cleared the faults twice and they still come back? what could this mean should i take it back to the guy that mapped it?
    Tim
  10. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    I would take it back and ask him to clear the fault codes. If he cannot do so, then something in the flash screwed communications. He needs to fix that.
