VCDS Lite
dplovin Jun 27, 2011
  1. dplovin
    dplovin Member
    416
    just done a auto scan on my audi s3 2000 reg and it came up with these results couldnt go no further tho as ive not got a licence yet any idea peeps help much appreciated?......
    VCDS-Lite Version: Release 1.1
    Monday, 27 June 2011, 18:26:47.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8L0 906 018 N
    Component: 1.8L R4/5VT 0002
    Coding: 05710
    Shop #: WSC 06435
    VCID: 3A07B1EB3551
    3 Faults Found:
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-10 - - - Intermittent
    16795 - Shareware Version. To Decode all DTCs
    P0411 - 35-10 - Please Register/Activate - Intermittent
    17956 - Shareware Version. To Decode all DTCs
    P1548 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: Redir Fail!
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V004
    Coding: 18448
    Shop #: WSC 06435
    VCID: 3E0FBDFB2979
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-10 - Electric Circuit Failure - Intermittent
    01423 - Shareware Version. To Decode all DTCs
    27-10 - Please Register/Activate - Intermittent
  2. <tuffty/>
    21,253
    3,880
    Here you go fella... even though the shareware version doesn't show all the text for fault codes you can look them up here..
    Category:Fault Codes - Ross-Tech Wiki
    For example...
    is... 16795/P0411/001041 - Ross-Tech Wiki
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuel Pump Relay (J17) faulty
    • Hoses/Pipes to/between Components faulty/clogged
    • Secondary Air Injection Pump (V101) faulty
    • Secondary Air Injection Pump Relay (J299) faulty
    • Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    • Check Fuel Pump Relay (J17)
    • Check Hoses/Pipes to/between Components
      • Check Secondary Air Injection Hoses/Pipes for Carbonization
    • Check Secondary Air Injection Pump (V101)
    • Check Secondary Air Injection Pump Relay (J299)
    • Check Secondary Air Injection Solenoid Valve (N112)
    ...and 17956 - Shareware Version. To Decode all DTCs
    is... 17956/P1548/005448 - Ross-Tech Wiki
    17956/P1548/005448 - Boost Pressure Controle Valve (N75): Open Circuit
    Possible Symptoms
    • Irregular behaviour
    • Loss of power
    • Limp mode
    Possible Causes
    • Wiring and/or connections faulty (short circuit)
    • N75 faulty
    Possible Solutions
    • Check wiring and connections
    • Check / Replace N75
    Have you cleared them all to see if they come back?
  3. dplovin
    dplovin Member
    416
    Good stuff mate I'll check now buddy nice 1, wouldn't let me clear them mate but I did replace the n75 the other day as me old 1 was dud kept stuttering on boost hopefully clearing them an they dnt come back, I've just ordered one of those liquid things lol that sit in ya air vent Think u can clear the codes with them? Then gna get full licence for vcds
