vcds interface not found?
bouncer117 Aug 31, 2012
  1. bouncer117
    bouncer117 Member
    307
    i have just recieved my vcds and installed it tried to conect to car and test but comes up saying port status: ok, interface: not found! does anyone have any ideas what this means? any addvice would be helpful thanks
  2. brasiliangringo
    brasiliangringo Member
    626
    10
    Is it genuine or the shareware + ebay lead ?
  3. bouncer117
    bouncer117 Member
    307
    shareware + ebay
  4. brasiliangringo
    626
    10
    No idea then could be a variety of issues not least the lead itself.
  5. bouncer117
    bouncer117 Member
    307
    is it likely to be a problem with the lead?
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    The port config will be wrong.
    Check what port the USB device is on, then change the port number to the VCDS port
  7. bouncer117
    bouncer117 Member
    307
    sorry for being thick but how do i do that?
  8. PAULF
    712
    66
    You need to go into device manager and hunt for the lead and then look at the settings. One of the settings will have the port number. In the start-up screen for VCDS, the is a test setting of some sort - I forget now - go to the test, and ensure the com port in use is the same as the one in your device manager. Then save the test BEFORE you get excited try and reprogram the toilet flush module.
    I'm assuming your using VCDS lite with the e-bay lead, which does have limited functionality.
    If you are using a pirate copy, this is norty :asskicking: and frowned on here.
    The e-bay leads are a bit of an ****, so you may end up wanting to speak to NHM if it all gets too much, as he will swap you a full CAN lead for the requisite number of beer tokens.
    I think you can still get a KII lead from Ross-Tech in the States, but TBH, the money saved is not really worth it. (I did that though)
  9. Todd1983
    Todd1983 Member
    147
    as above, will be incorrect com port, I had to do this with mine
  10. bouncer117
    bouncer117 Member
    307
    ok ill give it a try thanks muchly
  11. bouncer117
    bouncer117 Member
    307
    you were spot on thanks for the help
  12. bouncer117
    bouncer117 Member
    307
    it just gets better i have another problem wit it now lol tried scannin for faults it starts then a message comes up saying: a problem caused the program to stop working correctly. windows wil stop the program... any ideas lol?
  13. PAULF
    712
    66
    No idea on that one. It might be worth re-installing the program - or seeing if there is an anti-virus issue.
    I do refer you back to my post
    Some members get a bit excited over non-genuine leads, but to be honest, e-bay leads and the shareware VCDS work ok.
    However, if you find your using it a lot - get a genuine one as soon as, and get more options and less hassle.
  14. bouncer117
    bouncer117 Member
    307
    ok thanks for all your help
  15. aragorn
    18,545
    865
    Run it as administrator.
    Also, make sure your using VCDS Lite from the Rosstech page, and not the older shareware 409 version that lots of leads ship with, as 409 doesnt work with 64bit windows.
