VCDS injector fault.
Westy Jun 25, 2013
  1. Westy
    Westy Well-Known Member
    17,442
    1,100
    I know there's probably not a good time for any fault but a week an a half before Inters definitely isn't a good time!
    Anyway, has anyone had this fault before?:
    Ross-Tech says:
    17648/P1240 - Fuel Injector for Cylinder 4 (N33): Open Circuit
    Possible Symptoms
    MIL On
    Poor engine performance
    Possible Causes
    Fuse for injector
    Wiring harness issue
    Failed injector
    Failed ECM
    Possible Solutions
    Inspect fuse for injector
    Inspect wiring to and from injector, see repair manual
    Ohm test injector, replace if needed, see repair manual
    I'm running 1 year old Bosch 550cc injectors so I don't think the injector I the issue. I've swapped it over with cylinder 1 to see if the fault follows.
    I'm guessing wiring. I assume the injector wiring will break down in the same way as the coil pack wiring over time?
    If anyone has seen this before can you give me some advice? Thanks.
  2. Westy
    17,442
    1,100
    Now I'm fooked! Blue seal that sits in the fuel rail just dropped into the engine bay :(
    I've got the inlet mani off but I can't see it. Are these standard seals or do I need to order from Bosch?
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,802
    192
    steal them off another engine sat somewhere in the garage... :D
  4. superkarl
    superkarl MAN OF STEEL
    9,371
    2,368
    The rubber o-ring on the injector??
    Theyre pretty generic to bosch injectors. Ebay that shizzle
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Drama queen!...:laugh:
  6. Westy
    17,442
    1,100
    Found it nestling next to the coolant bottle! Anyway all back together now. Stated it up and no codes yet. I'll check again tomorrow after its done a journey.
  7. superkarl
    9,371
    2,368
    Hard to imagine injector wirimg to get damaged, doesnt see the heat the coilpack loom does. Perhaps just a weak connection?
    If you have a multimeter perhaps worth checking resistance across the pins to see if anything is odd.
  8. Westy
    17,442
    1,100
    It's funny you should say this. I prodded and wiggled all the wiring while it was on and there was no issue. I did spot when I swapped the injectors that the connectors inside the adapter plug is well loose and flimsy so could be that. With a bit of luck it's now sorted...
  9. Westy
    17,442
    1,100
    No error today. I'll keep an eye on it.
