vcds help cheshire/manchester
rOb_A Jun 30, 2012
  1. rOb_A
    rOb_A Active Member
    1,488
    looking to see if anyone can help with vcds in said above area.
    just want to check if my RNSe is sorted with the Bose, as the audio pilot seems to fluctuating the sound quiet alot (driving me mad!) to a point where i think the RNSe is really worth?! also to check the light levelling.
    if anyone can help out, that would be great :salute:
  2. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    OMG i was just in manchester forgot you needed vcds :keule:
  3. rOb_A
    rOb_A Active Member
    1,488
    :wacko: your car back on the road lad? could always meet you at Birch services if you have time? could get a look at your car
  4. amar06fbr
    1,055
    68
    nope still not out lol, went down in van to pick up a few parts :D
  5. rOb_A
    rOb_A Active Member
    1,488
    whats wrong with the car Amar? must suck, as the car looks great from the pics you have posted
  6. quattro81
    quattro81 All the gear.. No idea
    970
    90
    blob.. you still can't sort audiopilot with vcds!! You can only use it to sort out GALA in a non-BOSE system... for the BOSE it can only be done by re-wiring the BOSE amp in the boot! This stops it using the BOSE ambient noise mic in the front to constantly adjust the volume. If you cut the mic out from the front or any other way it gives you the "three-gong" warning :lmfao: on the nav unit every time you turn it on.
    As per the TSB here http://dejong947.com/audi/tsb/audi.tb.91-04-17.pdf
    your audi dealership can do it for you if you don't want to attempt it yourself!
  7. rOb_A
    rOb_A Active Member
    1,488
    Hi Chris, thanks for the PDF . yep think im going to get the tbs carried .
    Hoping NHN can do it for me, will pm him. when your new car arrive?
    cheers rOb
  8. az786
    az786 New Member
    20
    Sorry to hijack the thread but has anyone required the wiring for the stock amp in the boot of a sportback to a Bose unit? If so can you pm me just wanted a little help as I'm attempting this soon
  9. quattro81
    970
    90
    Audi should really take the time to look it up when you ask them! it's foooking annoying lol:D
    and NHN is the man to ask if he's not flat-out in demand as usual! It's a bit of both wiring and coding - after bose amp is rewired, Rns-e needs to be coded to enable gala, which you can then turn off on the nav unit itself in sound settings menu! bit of a faff, but once its done, it's done!
    and the new one is build week 38.. gonna be sad to see my 3 door go in some ways though....:(
  10. amar06fbr
    1,055
    68
    yea it suck but aye its gettin sorted now :D il p.m ya ;)
  11. rOb_A
    rOb_A Active Member
    1,488
    I'm going to get this done asap! will let others know how i get on. cheers Chis for your input :thumbsup:
  12. DaveA3-TDI
    DaveA3-TDI Member
    249
    Have you had this done yet?
