VCDS help 2.5tdi engine
Faizan Oct 24, 2017
  1. Faizan
    Faizan Member
    32
    Hi guys,
    I'm hoping I've posted this in the right section. I've been trying to help a chap out with a VW Crafter van (2.5 tdi CR engine). He's had his DPF replaced for a new unit at great expense, and he was hoping to have the soot level reset etc. I'm having issues accessing the engine security module as I don't know the security code.
    I've tried the 12233, and that doesn't work. Could anybody from here help?
    Thanks,
    Faizan
    P.s the scan is below
    Tuesday,24,October,2017,13:27:17:20893
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    VIN: WV1ZZZ2EZA6020975 License Plate: GK10YBU
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
    Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
    B0 B1 B2 B3 B4 B5 B6 C1
    Address 01: Engine (CEC) Labels: Redir Fail!
    Part No SW: 076 906 022 P HW: 076 906 022 G
    Component: R5 2,5L EDC A020DG 9022
    Revision: 24H32--- Serial number: VWXDZ0J1002253
    Coding: 0003078
    Shop #: WSC 00224 210 999999
    VCID: 204437AEF0927E46AA-5102
    1 Fault Found:
    009315 - Diesel Particle Filter
    P2463 - 000 - Excessive Soot Accumulation - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 819 /min
    Speed: 0.0 km/h
    Pressure: 62 mbar
    Hex Value: 0xFF00
    Temperature: 114.0°C
    (no units): 61.2
    Mileage: 670 km
    Readiness: 1 2 0 0 1
    Address 91: LT3 Engine Labels: Redir Fail!
    Coding: 0003078
    VCID: 204437AEF3927E46AA-8074
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 819 /min
    Speed: 0.0 km/h
    Pressure: 62 mbar
    Hex Value: 0xFF00
    (no units): 61.2
    Mileage: 670 km
    Address 92: LT3 Transmission
    Part No SW: 9069024500 HW: 9065450932
    Shop #: WSC 82495 007 00000
    ASAM Dataset: 48 1
    ROD: CRFT_TCM_48_1.rod (*)
    VCID: 030E58228A44855E97-8056
    No fault code found.
    Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
    Part No SW: 2E0 905 865 AD HW: 906 545 580 8
    Component: IMMO 0805 0815
    Revision: 00805000 Serial number: VWXDZ0J1002253
    Shop #: WSC 00000 000 00000
    VCID: 6DDA1E9A74C0632E51-8038
    Address 94: LT3 Airbag
    Part No HW: 9064461442
    Shop #: WSC 00117 555 00000
    ASAM Dataset: 3 3332
    ROD: CRFT_AB_3_3331.rod (*)
    VCID: 55AA567A3450CBEE89-8000
    Address 95: LT3 ESP
    Part No SW: 9069022800 HW: 0004460153
    ASAM Dataset: 3 4101
    ROD: CRFT_ESP_3_36946.rod (*)
    VCID: 040C5B3E8F4A8266AE-8050
    Address 96: LT3 Instruments
    Part No SW: 9069024700 HW: 9069012000
    ASAM Dataset: 32 786
    ROD: CRFT_KOMBI_32_786.rod
    VCID: 050A463A8470BB6EB9-8050
    Address 99: LT3 Ign. Switch
    Part No HW: 9065455808
    ASAM Dataset: 67 257
    ROD: CRFT_EZS_67_257.rod (*)
    Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
    Component: HF-FFB 0805 0815
    Revision: 00805000 Serial number: 12345678901234
    1 Fault Found:
    00171 - Key 1 not learned
    000 - - - Intermittent
    Address 9B: LT3 Driver Door
    Part No HW: 9068205626
    ASAM Dataset: 33 260
    ROD: CRFT_FTUHR_33_260.rod
    1 Fault Found:
    900A - Driver's heated mirror: Short to Plus
    Test Complete - Active/Stored
    Address 9C: LT3 HVAC
    Part No SW: 2514450200 HW: 9068301085
    ASAM Dataset: 21 2
    ROD: CRFT_KLIMA_21_2.rod (*)
    VCID: 77F63CF2CE9CD9FEBB-8022
    2 Faults Found:
    9201 - Temperature Regulator Flap Motor Position Sensor (G92): Open or Short to Plus
    9301 - Temperature Regulator Flap Motor (V68): defective/open circuit/short circuit
    Test Complete - Stored
    Address B0: LT3 Roof Display
    Part No SW: 9069021000 HW: 9069010900
    ASAM Dataset: 21 3
    ROD: CRFT_DBE_21_3.rod (*)
    VCID: 7BFE20C2F2B4FD9EDF-802E
    1 Fault Found:
    909B - Alarm Horn (H12): No communication
    Address B1: LT3 Upper Console
    Part No HW: 9065454107
    ASAM Dataset: 67 3
    ROD: CRFT1_OBF_67_3.rod (*)
    1 Fault Found:
    9026 - CAN data bus: No communication
    Address B4: LT3 Central Elec.
    Part No SW: 9064420700 HW: 9065453801
    ASAM Dataset: 33 772
    ROD: CRFT_EZE_33_772.rod (*)
    2 Faults Found:
    90A6 - Fuel level sensor: Short to Plus
    901D - License plate lights/side-marker lights: Open circuit
    Address B6: LT3 Steering Wheel
    Part No SW: 9065402345 HW: 9065402345
    ASAM Dataset: 72 257
    ROD: CRFT_SML_72_257.rod (*)
    VCID: 06084136B976B076B0-8052
    End-------------------------(Elapsed Time: 03:42)--------------------------
  2. myke
    myke Member VCDS Map User
    97
  3. myke
    97
    edc17 if the soot level is too high you can not reset, where are you looking Instruments or ecu ?
    What is the soot level showing in live data?
