Hello,
I got a full scan performed by a forum member who was more than helpful. But neither of us understood the output too well. It has thrown up lots of faults and often the same one appears many times.
Some faults are time and date stamped whereas others arent..why is this?
The problem i am trying to resolve is an intermittant drain on the battery where the clocks in the instrument cluster turn on randomly when the car is locked and has been locked for a while. They then stay on until the battery is completely drained.
I have pasted the output below, and hopefully someone will be able to understand it.
VCDS Version: Beta 812.4
Data version: 20090214
Friday,13,March,2009,19:13:54:26365
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P75A082360 Mileage: 71570km/44471miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door,Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03C 906 056 AP HW: Hardware No
Component: MED9.5.10 00 7000
Revision: 00000000 Serial number: AUX7Z0DNFN10DT
Coding: 0000072
Shop #: WSC 06314 000 00000
3 Faults Found
16580 - Engine Oil Temp. Sensor (G8): Implausible Signal
P0196 - 004 - No Signal/Communication
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 008 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0019077
Shop #: WSC 06435 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
Component: KlimavollautomatH13 0150
Revision: 015040 Serial number: 8P0820043F
2 Faults Found
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 70570 km
Time Indication: 0
Date: 2011.06.03
Time: 19:06:21
Freeze Frame:
Voltage: 12.40 V
Temperature: 31.0°C
(no units): 192.0
(no units): 33.0
Temperature: 21.5°C
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001208363
Coding: 058C4F02B014100000160000160000000000FE0F5C
Shop #: WSC 00000 000 00000
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00000
3 Faults Found
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 003620010NNF
Coding: 0034622
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 0 km
Time Indication: 0
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 T HW: 8P0 920 980 T
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 224NDD04000558
Coding: 0004443
Shop #: WSC 01179 210 93569
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104A2505A1
Coding: 3D3F0342072103
5 Faults Found
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:00:08
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 6
Reset counter: 151
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:08:18
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:08:44
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:09:14
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D04 Serial number: AUX7Z0DNFN10DT
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000120
1 Fault Found
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.7 1502
1 Fault Found
00750 - Warning Lamp
013 - Check DTC Memory - MIL ON
Freeze Frame:
Mileage: 7160 km
Temperature: -1.0°C
Voltage: 11.70 V
Voltage: 11.50 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D088505489FC63000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
2 Faults Found
00926 - Terminal 30
011 - Open Circuit - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001207374
2 Faults Found
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 13:48:44
Freeze Frame:
Temperature: 17.0°C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 13:48:05
Freeze Frame:
Temperature: 17.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000120
1 Fault Found
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H57 0410
Revision: 22S Serial number: AUZ5Z4D6047920
Coding: 0001001
3 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Freeze Frame:
Bin. Bits: 00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 12:48:59
00858 - Connection; Radio ZF Output to Antenna Amplifier
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 71044 km
Time Indication: 0
Date: 2011.06.23
Time: 05:25:21
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000216
3 Faults Found
01813 - Supply Voltage for Door Controller; Rear Left (J388)
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000216
1 Fault Found
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000072
3 Faults Found
Coding: 0019077
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 70570 km
Time Indication: 0
Date: 2011.06.03
Time: 19:06:21
Freeze Frame:
Voltage: 12.40 V
Temperature: 31.0°C
(no units): 192.0
(no units): 33.0
Temperature: 21.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Coding: 00062736
Shop #: WSC 00000
3 Faults Found
Coding: 0034622
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 0 km
Time Indication: 0
Coding: 0000012
Coding: 0004443
5 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:00:08
Freeze Frame:
Fault Priority: 1
Fault Frequency: 6
Reset counter: 151
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:08:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:08:44
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 143
Mileage: 71028 km
Time Indication: 0
Date: 2011.06.23
Time: 00:09:14
Coding: 0000120
1 Fault Found
1 Fault Found
Freeze Frame:
Mileage: 7160 km
Temperature: -1.0°C
Voltage: 11.70 V
Voltage: 11.50 V
2 Faults Found
00926 - Terminal 30
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 13:48:44
Freeze Frame:
Temperature: 17.0°C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 13:48:05
Freeze Frame:
Temperature: 17.0°C
Coding: 0000120
1 Fault Found
Coding: 0001001
3 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Freeze Frame:
Bin. Bits: 00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 154
Mileage: 70800 km
Time Indication: 0
Date: 2011.06.12
Time: 12:48:59
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 71044 km
Time Indication: 0
Date: 2011.06.23
Time: 05:25:21
Coding: 0000216
3 Faults Found
Coding: 0000216
1 Fault Found
