VCDS for Ipad
quattrov6tdi Apr 27, 2013
  1. quattrov6tdi
    quattrov6tdi Member
    77
    Is it possible?
    And is it dangerous to clear fault codes?
    If they don't return when you you rescan,does it mean that they fixed themselves or were intermittent?
    Sorry bit of a novice but have a touran now as well so I best learn
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    159
    RT are bringing out a mobile version in the near future but for now it's not possible.
    quattrov6tdi likes this.
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I wonder if you bought an windows xp tab with USB ports if it would work
  4. Gizmo68
    Gizmo68 VCDS owner in Kent VCDS Map User
    88
    As Chris said, VCDS-Mobile is due out shortly (it is going to be dearer than the current HEX+CAN interface).
    Save the scan then clear the fault codes, they will not ‘fix themselves’ but if the fault does not reappear (intermittent fault) then the DTC will stay cleared.
    I cannot see why it would not work on an XP tablet with a USB port (I currently use a netbook)
