VCDS Fault codes inside' Solving it
Paul @ Unit 9 Remaps Nov 3, 2012
  1. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    Searched and not found an exact reason. VCDS Codes below.
    Replaced the Wheel speed sensor cleaned the ring and inspected and changed key fob battery. but no change and now have these codes. its pissing me off, I have ABS light' Traction light and engine management. its intermitten abs and traction only comes on when stationary or second time turning the cart back on also have no speedo which is also intermitten (not all the time)
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04495
    Shop #: WSC 06435
    VCID: 264881E4C20EBB287B9
    1 Fault Found:
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    30-00 - Open or Short to Plus
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0203
    Coding: 00001
    Shop #: WSC 63351
    VCID: 32606DB4FEC6D788E71
    1 Fault Found:
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    So i have done.
    Replaced with new sensor and cleaned and inspected everything and no joy. and the speedo not working 50% of the time puzzles me too
  2. Paul @ Unit 9 Remaps
    2,035
    132
    Last thing a need to double check on monday is wiring but sure its fine
  3. Paul @ Unit 9 Remaps
    2,035
    132
    anyone' ive changed the wheel bearing too now hoping it would solve it' got it in my head that it might only happen on lock :(
  4. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    sounds like abs unit , if traction control will not turn off
  5. Paul @ Unit 9 Remaps
    2,035
    132
    need to test it some how. googled abit but havnt found much
