VCDS fault codes EVAP & Control Module 1 Fan error, any advice please?
motffc Jan 2, 2014
  1. motffc
    motffc New Member
    Hi All,
    Got onto VCDS as wanted to check the state of my car. It's A3 2.0 FSI 2004 engine AUX. I've pasted the fault codes below. I cleared them a few days ago and these ones have come back. And yes my Fans sound like jet engines! :faint:
    Also i think i've just found a coolant leak on the bottom passenger side of the radiator. BTW these codes were present before the leak.
    I've been looking around and it suggest i should maybe replace the N80 valve and the Charcoal cannister...
    Then the Fans, I have already replaced fuse F8 and cleaned the contacts. Reckon this is a fan pack replacement?
    Any advice on the codes will be appreciated thanks!
    VCDS out put:
    Address 01: Engine Labels: 06F-906-056-AXW.lbl
    Part No SW: 06F 906 056 CP HW: Hardware No
    Component: MED9.5.10 00 5787
    Revision: 00000000 Serial number: AUX****************
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 79FF83F730BED1D6D3D-802C
    Subsystem 1 - Part No: 06F 907 807 E
    Component: NOX 0403030122 005 4009
    06F907807E NOX 0403030122 005 4009
    2 Faults Found:
    16825 - EVAP Emission Control Sys
    P0441 - 008 - Incorrect Flow - Intermittent
    18354 - Control Module 1 for Coolant Fan
    P1946 - 004 - Defective - Intermittent
    Readiness: 0000 0000
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,752
    659
    I've had a similar error on my golf for the fan module, I cleared it a few times but it just came back. I replaced the main fan and the fault went away. From the looks of things it's a common fault.
  3. motffc
    motffc New Member
    yeah I've heard it's a common thing.. :sob: going to try and grab a mechanic mate tomorrow so hopefully i can get trade priced parts.
