vcds fault code
lee58uk Jan 18, 2012
  1. lee58uk
    lee58uk New Member
    9
    hi i brought a a3 , put laptop on it, as on way home it didnt boost as well as i hoped.
    2001 a3 1.8T quattro sport 94k ary engine should be fitted but looks like an AUM has been put in around 05 as lots of new parts date stamped , power steering pump, a/c pump pipes to engine
    any way the faults are with abs n/s/f sensor code
    haldex fault, N249 valve? air bag
    any comments or easy fix
    Friday, 13 January 2012, 21:04:26.
    VCDS-Lite Version: Release 1.1
    Control Module Part Number: 02D 900 554 B
    Component and/or Version: HALDEX LSC ECC 0006
    Software Coding:
    Work Shop Code:
    VCID: 1F31607F8EB3
    3 Faults Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    00526 - Shareware Version. To Decode all DTCs
    27-10 - Please Register/Activate - Intermittent
    01316 - Shareware Version. To Decode all DTCs
    79-10 - Please Register/Activate - Intermittent
    Monday, 16 January 2012, 18:56:25.
    Software Coding:
    Work Shop Code:
    VCID: 1F31607F8EB3
    1 Fault Found:
    00-00 - -
    Sunday, 15 January 2012, 16:37:36.
    Control Module Part Number: 06A 906 032 HN
    Component and/or Version: 1.8L R4/5VT 0001
    Software Coding: 10710
    Work Shop Code: WSC 01236
    VCID: 719556C728A7
    Additional Info: WAUZZZ8L221002813 AUZ7Z0A1898040
    2 Faults Found:
    17695 - Boost Pressure Control Valve (N249): Open Circuit
    P1287 - 35-00 - -
    16486 - Shareware Version. To Decode all DTCs
    P0102 - 35-10 - Please Register/Activate - Intermittent
    Monday, 16 January 2012, 18:51:01.
    Control Module Part Number: 1C0 907 379 F
    Component and/or Version: ESP ALLRAD MK60 0104
    Software Coding: 0023046
    VCID: 2D2D8AB7F41F
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    00283 - Shareware Version. To Decode all DTCs
    012 - Please Register/Activate - Intermittent
    Friday, 13 January 2012, 21:06:22.
    Control Module Part Number: 8L0 959 655 J
    Component and/or Version: Airbag Front+Seite 5008
    Software Coding: 01104
    VCID: 45FDD2174CAF
    1 Fault Found:
    00588 - Airbag Igniter; Driver Side (N95)
    32-10 - Resistance too High - Intermittent
  2. <tuffty/>
    20,990
    3,760
    Useful site for fault code info...
    Category:Fault Codes - Ross-Tech Wiki
    Anyhoo... haldex one could be an earth strap or the plug behind the diff... essentialy a lack of power
    65535 - Ross-Tech Wiki
    N249 fault sounds like its just unplugged... maybe an N249 bypass that the original owner did and removed or unplugged the N249 valve that controls the DV
    01314 - Ross-Tech Wiki
    Faulty wiring maybe...
    00588 - Ross-Tech Wiki
    Take your pick from that list :)
