VCDS Errors on ABS and Knock Sensor?
vfr800 May 8, 2013
  1. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Hi
    I was driving the car the other day and whilst braking on some bumpy tarmac the ABS kicked in for a split second. No problems, arrived at work, when I got in the car and started it to leave work the ESP and ABS warning lights came on and have stayed illuminated on the dash ever since.
    I scanned the car these two errors came up, I know they're unrelated, probably:
    VCDS-Lite Version: Release 1.2
    Friday, 03 May 2013, 15:39:45:5805
    Control Module Part Number: 8N0 907 379 E
    Component and/or Version: ESP 20 CAN V005
    Software Coding: 18448
    Work Shop Code: WSC 01236
    VCID: 3E0FAB56296F
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    35-00 - -
    I can't clear this error - I've checked the plug on the sensor and it all seems fine. New sensor needed?
    GSF have pattern sensors for about £17 or should I get a OE one?
    Any ideas on the second, unrelated, error would be appreciated ...
    Friday, 03 May 2013, 15:39:02:5805
    Control Module Part Number: 8N0 906 018 J
    Component and/or Version: 1.8L R4/5VT G 0004
    Software Coding: 10710
    VCID: 3803BD4E0B4B
    Additional Info: ****
    1 Fault Found:
    16712 - Knock Sensor 1 (G61): Signal too High
    P0328 - 35-10 - - - Intermittent
    What does this mean? My googling hasn't really enlightened me. As far as I know the knock sensor hasn't been touched ... I don't even know where it is.
    Thanks, Liam
  2. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I had the first code (same corner) and replaced the sensor with an OE one, problem solved. Didn't consider a GSF one at the time.
    Can't help with the second one.
  3. vfr800
    775
    57
  4. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Check for a break in the loom somewhere?
    the knock sensor could have triggered when the esp kicked in , does that code clear and stay cleared?
    location... google says under the front manifold, will be a heavily shielded wire and bolted into the block.
  5. vfr800
    775
    57
    @udi A3 - thanks - good point. I did clear the code I'll check it out.
    I might go to GSF and get a cheapo ABS sensor and see how that goes.
    Liam
  6. @udi A3
    1,819
    197
  7. @udi A3
    1,819
    197
    if you go to the thread that pic is from theres a lot more photos, including shiney engine porn lol
  8. vfr800
    775
    57
    Thanks. mmmm engine pr0n. :)
    Looks simple - I'll check the codes again ... hopefully it will not have come back.
  9. <tuffty/>
    21,581
    4,053
    knock sensor 1 is located under the inlet manifold just to the right of the thermostat housing... I did indeed have this same issue and I re-wired the sensor back to the ECU... 2 core screened cable is required to do this...
    Sensor G61, pins on ECU below...
  10. vfr800
    775
    57
    Thanks for the info Tuffty.
    I have scanned again and the error has not re-occurred. Maybe it was a one off or as it says, an intermittent fault which will come back.
  11. <tuffty/>
    21,581
    4,053
    Mine was intermittent... it would happen randomly and the rewire made it go away and is still fine today...
    These kind of faults are like that... :(
  12. vfr800
    775
    57
    Thanks.
    I have one coil pack that keeps working its way out. Would a coil pack making a bid for freedom cause this?
  13. <tuffty/>
    21,581
    4,053
    Very much doubt it (although stranger things have happened...)
    cut a small section of rubber out from the retaining ribs of the coil pack... reason they list is the air trapped as you push the pack in heats up and any oil etc on the rocker means the rubber bit of the pack can't grip and subsequently the pack rises up from the the expanding air... small slot in the rubber will let the air out (might be worth degreasing the coil pack holes too)
  14. vfr800
    775
    57
    That's a good idea to cut a vent in, I have degreased the holes and the coil pack several times, which slowed it down.
    Cheers, Liam
  15. vfr800
    775
    57
    So I picked up a cheapo £17 ABS sensor from GSF. I thought it would be simple to replace.
    I drove the car up on some ramps so I could get underneath and put plenty of penetrating spray on the old sensor.
    Undid the 5mm allen bolt holding it on, it took about 1 min of gentle coaxing with the screw driver and pliers in an attempt to free the old sensor to do this instead.
    Oooops! Doh! It snapped off. Now I had to lift the car up put it on axle stands and remove the wheel to get to the remains.
    Used a small chisel to slice off the remains of the old sensor poking out the other side.
    Once the copper coil was remove from the insides there was a cylinder of plastic left in the hub which took a while to hammer and pry out.
    Once it was out and the hole was cleaned it was simple to reassemble and put the new sensor in.
    Cleared all the fault codes and my dash no longer looks like a christmas tree. Happy days!
    I know it's a cheap sensor but it has a 1yr warranty so I'll see how it goes. Thank god it was a cheap fix.
    Liam
  16. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,320
    10,269
    Liam, sounds like a bad day. Why do these things always happen at the weekend or when there is nowhere open for you to get help? Its fixed now and your dashboard is back to normal, now you can just drive it again. :) x
