VCDS Error codes
hodgy0_2 Oct 1, 2012
  1. hodgy0_2
    hodgy0_2 Member
    97
    I have the following error code
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    it appears in two modules
    ABS/ESP module and the Gearbox module
    are they the same component flagging error
    can't find much info on these codes
    any help appreciated
    the car is a A4 2.5TDI Quattro
  2. NHN
    29,596
    1,782
    Where's the full log?
    Have you checked in ecu for any errors?
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
  4. hodgy0_2
    hodgy0_2 Member
    97
    is this any good
    Sunday, 30 September 2012, 13:14:44.
    Control Module Part Number: 8E0 927 156 L
    Component and/or Version: AG5 01V 2.5lTDI RdW 2121
    Software Coding: 00001
    Work Shop Code: WSC 63351
    VCID: 3701A8DF0643
    1 Fault Found:
    P1857 - 35-10 - - - Intermittent-
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04357
    Shop #: WSC 00861
    VCID: 263F759BD1E9
    2 Faults Found:
    01119 - Shareware Version. To Decode all DTCs
    35-10 - Please Register/Activate - Intermittent
  5. NHN
    29,596
    1,782
    Delete the code from ecu module 01 & see if it comes back, what exactly is the car issue though?
  6. hodgy0_2
    hodgy0_2 Member
    97
    thanks for the reply HNH
    well, the issue is my ESP light lights up occasionally -- usually after a gearbox judder (has done this for a year or two)
    and very recently the car acts like it has a slipping gearbox -- but the fluid is quite new, and I believe topped up to the correct level
    I am trying to locate the TCM to check the connectioms etc if you know where that might be?
