VCDS DPF Soot Level
DaveA3-TDI May 23, 2012
  1. DaveA3-TDI
    DaveA3-TDI Member
    249
    I had my car checked with VCDS the other day as I was trying to find out what the soot level in my dpf was so I went into engine and then measuring blocks 08 and looked at channels 070 & 075 and it told me the lambda was at 21.6% , does this sound about right? From what I can find out on here and other sites sometimes it says lambda instead of soot load but means the same thing?
    Is this the correct way to check the level?
    Oh car is 2.0 Tdi 170
  2. Rhyso
    Rhyso Well-Known Member
    1,482
    304
    Yes you are correct
    If you can, take it for a drive and get the pre-turbo temperature up past 750c and you may see a regen start to take place and the soot % falling :)
  3. DaveA3-TDI
    DaveA3-TDI Member
    249
    Thanks, I have read that the dpf light can come on when it hits 45%. As mine is reading 21.6% is that good or bad, what is an average reading?
    i only started looking into all this as the over day when I got home the car was ticking over at around 1,000 rpm instead of the usual 800rpm. I sat there for a couple of minutes and then it went back down to 800rpm, any idea what was happening?
  4. Rhyso
    1,482
    304
    Its about average; mine reaches 30% sometimes and then i give it a good hammering!!
    Passive regen by the sounds of it ;)
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    How often or how does the car decide when to do a passive regen?
  6. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Every 100 miles or so
  7. DaveA3-TDI
    DaveA3-TDI Member
    249
    Why does it do it so often?
  8. max69vk
    max69vk Active Member
    862
    57
    Depends in your driving style, in reality every 300 miles is probably a more realistic regen cycle.
  9. a6_chris
    1,883
    160
    Oops - I thought it was every 100.
    My DPF light has come on too many times on my A3 - I do 600 miles per week all motorway so it shouldn't be coming on but this is down to the long 5th gear in the E so a blast in 4th sorts it out.
  10. max69vk
    862
    57
    I've had mine come on 5 times in 350 miles, mind you I've just found out the turbo is faffed!
  11. Gogsie
    Gogsie Member
    32
    Just get the thing ripped out!. I have done this on my A4 and it's the best thing I ever did!
  12. DaveA3-TDI
    DaveA3-TDI Member
    249
    I probably do 100 miles a day on country roads so I am hoping that I won't get any problems with the DPF, isn't the DPF required for an MOT?
  13. Rhyso
    1,482
    304
    No its not - here's a reply i had from VOSA direct;
    From an MOT perspective a compression ignition (diesel) engine must meet
    the specific emission limits as prescribed in the Private Passenger and
    Light Commercial Vehicle Inspection Manual (IM). Particulate filters are
    not part of the MOT. However, particulate filters are, as their name
    implies, fitted to filter out particulates (soot) in the exhaust gases and
    as a method to meet current emission requirements. It is possible that
    removing the particulate filter may affect engine performance and it's
    ability to meet the relevant emission requirements.
    However any body removing an emissions component should consider that the
    vehicle may have been type approved to certain level which includes the DPF
    and that it's removal could contravene.
  14. DaveA3-TDI
    DaveA3-TDI Member
    249
    I am thinking of having the DPF removed now and how found a company local to me in Stroud called Turner Race Developments, has anyone used these guys?
  15. DaveA3-TDI
    DaveA3-TDI Member
    249
    I am having issues with my car at the moment!! When driving around town on light throttle keeping up with the traffic engine revs between 1800-2000 rpm sometimes the car will hesitate, bit like a mis-fire, power dips and back on again. I have also noticed that sometimes if I stop, the engine idle speed increases to around 1,000rpm and then will drop back down to around 800rpm after a couple of minutes.
    The car is a 2.0 litre TDi 170 and has started doing this more and more. If I keep driving though after 10 mins of putting up with the hesitation etc the car will then suddenly run fine and be ok till it does it again. When it has it's moment of hesitation it is fine if I am hard on the throttle or at speed.
    I am wondering if I could have a problem with the DPF although I have never had a light come on or could these be symptoms of a failing EGR valve?
    Can anyone help with suggestions or ways I could check? I am still thinking about having the DPF removed by Turner Race Developments, is this a good idea or can anyone recommend this company?
    Thanks in advance
  16. a6_chris
    1,883
    160
    Your first paragraph is describing a regen as far as my knowledge reaches ;)
  17. DaveA3-TDI
    DaveA3-TDI Member
    249
    I did think it sounds like a regen but I never had the DPF light come on and it seems to be doing it almost every journey I make now! I travel about 60-70 miles a day which can include fast roads and built up area driving.
    I am not sure whether to go down the DPF removal root of EGR replacement route?
  18. max69vk
    862
    57
    Your car is going into 'Passive regen' to burn off the soot, nothing to worry about it's normal. This happens when soot levels hit 40%
    If you dont clear it out or the regen fails (doesn't complete) it will then flash a warning on the dash & go into 'Active regen', this occurs at 60% soot levels.
    If even after taking the car for a good long booting the light still doesnt go out, or soot levels drop (below 75%), you will need to get the car into a garage or use VCDS to do a 'Forced regen' to try & clear it.
    If Soot levels raise above 85% you can pretty much consider the DPF as fubar!
  19. DaveA3-TDI
    DaveA3-TDI Member
    249
    I don't understand why it keeps doing it almost every day at the moment? Shall I just get the dam thing removed?
  20. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
  21. max69vk
    862
    57
    It may not be fully completing its regen cycle, so it stops the process till it then thinks its has a chance to fully regen, then realises that the levels are rising again & tries to do the regen yet again, its all reasonably normal though. I had one passive regen process 'fail' 6 times because I didnt drive it enough when it was attempting to regen, but the next time I drove it it sorted itself out out. The DPF can be a bit fickle at times!
  22. DaveA3-TDI
    DaveA3-TDI Member
    249
    Is there anyway with VCDS to see if the regen has failed?
  23. a6_chris
    1,883
    160
    Not sure but you can check the soot level in Measuring Block 075 (or there abouts) in the Engine module.
  24. DaveA3-TDI
    DaveA3-TDI Member
    249
    I will check later and see what is going on, would it be worth forcing a regen?
  25. a6_chris
    1,883
    160
    Depends on the level - go for a 25 minute drive in 3rd first (around 2500 rpm) though to clear it out a bit first before forced regen.
  26. DaveA3-TDI
    DaveA3-TDI Member
    249
    Ok, would it then be ok to follow these instructions from the ross-tech website? The section for the PD engine?
  27. a6_chris
    1,883
    160
    Yep the instructions on rosstech is what you need.
    But forced regen is only really needed if the light doesn't go out.
  28. DaveA3-TDI
    DaveA3-TDI Member
    249
    I see, the light has never appeared on my car?
  29. a6_chris
    1,883
    160
    No need to force regen then ;)
    Infact you only need to panic when the dpf and engine light appears.
  30. DaveA3-TDI
    DaveA3-TDI Member
    249
    I guess the only way forward then to stop the car feeling like a bag of **** when it decides to do it's regen is get the DPF removed. Any advice welcome regarding this? At least it doesn't sound like the EGR valve.
    thanks
  31. DaveA3-TDI
    DaveA3-TDI Member
    249
    Just been out and checked the car and the DPF soot level was at 34% and that was after 24km since it's last regen!! I forced a regen on the DPF following the Ross-tech instructions and drove it around for 25 mins and managed to get the level back down to 11.9%. I then drove normally and watched as the DPF level kept rising, have stopped now and the DPF level is at 15.9%
    What I noticed whilst it was doing it's forced regen was the car started driving horribly as I described previously but once it had finished and was down to the 11.9% it was sweet drive.!!
  32. Cossie_boy
    Cossie_boy Member
    472
    Dave, this is exactly what mine seems to be doing, is yours ok now?
    As you say, if revs are at 1000 rpm it runs bad and annoyingly hesitates making a horrible drive, then once sorted and back to 800 rpm its like a dream!
    I also have an added intermitent hesitation over 3k in 4/5/6th gears, but more convinced the low revs is the poxy DPF
    Does everyones car do this **** driving whilst DPF does its thing or do we have faults?!
    My light has only ever come on once, today!
  33. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Totally normal mate, nothing to panic about.
    The only fault really is the design of these stupid DPF's!!
  34. Cossie_boy
    Cossie_boy Member
    472
    Madness Danny, lol, I cant help feel mine does this a little too often though, to work is about 15 minute drive at 70 ish when I can and is up to temp before I get to office, hoped this was ok?
    Wasnt there a thing where after injector and loom recall they done an ecu update to make the dpf regenerate more?
    Mine is going back to place i got it tomorrow then to audi to be put back to standard on ecu so not sure how thats gonna affect anything, plus they need to check the dpf at same time as noticed some black soot around bulkhead!
  35. DaveA3-TDI
    DaveA3-TDI Member
    249
    I got so fed up with it and after speaking to a few people just got the DPF internals removed. Best thing I did, car is much better to drive without it.
  36. Cossie_boy
    Cossie_boy Member
    472
    hmmm, its crossed my mind, need them to get it all smoothed out first!
