VCDS coding
Fanoe Dec 15, 2013
  1. Fanoe
    Fanoe New Member
    26
    According to a buddy of mine, then VCDS coding on the 8V is not possible yet. Most of it supposedly locked.However according to this German page Stemei VCDS, then most things should be possible.Does anyone have any experience regarding what is possible?
  2. h5djr
    9,374
    1,724
    Try having at look at this thread on the GTI Forum. The new GTI uses the same engines and many of the same electronics as the Audi A3 8V so many of the items may well work with it as well.
    http://www.golfgtiforum.co.uk/index.php?topic=260248.0
  3. Splathead
    Splathead Active Member Team Estoril VCDS Map User Audi S3
    252
    89
    Yep, it works. I have carried out the following: - Changed the comfort indicators to 4 repetitions. - Enabled the Parking Sensor Display on the MMI. - Turned the rear lights on permanently as DRLs.
  4. Fanoe
    Fanoe New Member
    26
    Sounds great, going to have parking sensors retrofitted next week.Would also like to retrofit the retractable mirrors, but not sure about the coding?Danish taxation makes retrofitting good business ;-)
  5. RobH_S3
    RobH_S3 Active Member
    440
    208
    43
    I want the rear lights on permanently aswell.
    Also want coming/leaving home lights activated if you know how?
  6. Fanoe
    Fanoe New Member
    26
    Thanks, will copy the coding and show it to my buddy, hopefully it will work.
  7. lloydie1994
    lloydie1994 Active Member
    101
    31
    Is the coding of the Visual Parking Sensors available only if you ordered 7X2 or is it possible on the 7X1 option?Edit: Found myself according to stemei.de it is possible with just the rear sensors.
  8. Fanoe
    Fanoe New Member
    26
    Been reading about the VCDS possibilities for the Golf VII in the Golf GTI Forum, and they mention a code to access the central electronics menus. Is this also required on the A3, and if so, is it the same code (31347)?And does anyone know what coding is required if I retrofit the electrical retractable mirrors?
    M11 CUV likes this.
  9. c.grex
    c.grex Active Member
    141
    33
    Has anybody had any success with enabling TPM?
