I know I need the B&O amp component protection removing but the part numbers seem odd.
Will the speaker error go when I have the protection removed?
Help with any of the other would be appreciated.
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0140
Revision: D1000000 Serial number: 0105.08.080797
Coding: 36060000
Shop #: WSC 06325 000 00000
VCID: 4385A987C2600306C91-8016
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 123064 km
Time Indication: 0
Date: 2008.05.27
Time: 00:00:28
I think the battery was disconnected at this point
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0094
Revision: 4EB40045 Serial number: 4500E088098229
Coding: 000303
VCID: 4999BBAFE04CD95603D-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 72
Mileage: 123064 km
Time Indication: 0
Date: 2008.05.27
Time: 00:00:44
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 114
Mileage: 123184 km
Time Indication: 0
Date: 2017.03.30
Time: 08:23:00
Now it's these numbers that are confusing me
Part No SW: 8Q0 035 226 T HW: =T0 035 273 F
Address 47: Sound System (J025) Labels: None
Component: DVP Prem% H44 0100
Revision: 05H14004 Serial number: 31821020540104
Coding: 000500
Shop #: WSC 77872 026 394758
VCID: 3F8DA577AE8867E6AD9-806A
6 Faults Found:
00870 - Bass Speaker Front Left (R21)
002 - Lower Limit Exceeded
Freeze Frame:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
011 - Open Circuit
Freeze Frame:
03364 - Condition of Hard Drive
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
000 - -
Freeze Frame:
03170 - Temperature Sensor for Seat; Front Left
000 - -
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 10
Mileage: 113397 km
Time Indication: 5
Freeze Frame:
Voltage: 11.93 V
Temperature: 30.0°C
Temperature: 26.0°C
Bin. Bits: 00000100
Bin. Bits: 00000010
Voltage: 0.000 V
Ign. Timing: 2.9 °BTDC
Raw, Form. N/A: 000 000 000
Coding: 36060000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 123064 km
Time Indication: 0
Date: 2008.05.27
Time: 00:00:28
Coding: 000303
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 72
Mileage: 123064 km
Time Indication: 0
Date: 2008.05.27
Time: 00:00:44
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 114
Mileage: 123184 km
Time Indication: 0
Date: 2017.03.30
Time: 08:23:00
Coding: 000500
6 Faults Found:
Freeze Frame:
011 - Open Circuit
Freeze Frame:
011 - Open Circuit
Freeze Frame:
Freeze Frame:
000 - -
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 10
Mileage: 113397 km
Time Indication: 5
Freeze Frame:
Voltage: 11.93 V
Temperature: 30.0°C
Temperature: 26.0°C
Bin. Bits: 00000100
Bin. Bits: 00000010
Voltage: 0.000 V
