VCDS BRAKE BLEEDING, help please ?
HOTTIGGER Aug 25, 2012
  1. HOTTIGGER
    HOTTIGGER Member
    99
    hi all, can i bleed my brakes with vagcom? ive broken 1 of the small bleed nipples off the master cylinder, while trying to bleed my brakes, and i need to know if you can bleed them through vagcom without having to change the broken bleed nipple on the m/c ?, if so how ? is this the correct way VCDS (VAGCOM) ABS Bleed Procedure - uk-mkivs ?? anything else i need to know ? please help
    thanks in advance martin.
  2. Broken Byzan
    13,237
    465
    All that's for is bleeding the ABS module after completly emptying the system. You need to fix that broken nipple, no electronic aid is going to get the air out of a broken MC
  3. HOTTIGGER
    HOTTIGGER Member
    99
    it was bleed a few months ago at a vw garage with vcds and it had the same broken nipple,so it can be done m8!, the garage is closed, ive got vcds,, any help ?
  4. Broken Byzan
    13,237
    465
    I know it can be done, what i'm saying, unless you've drained the system right out it won't bleed any better than the manual method. Give it a try, nothing to lose
  5. HOTTIGGER
    HOTTIGGER Member
    99
    I carn't do the manual method, 1 of the nipples is broken off the m/c, its bin done b4 so can defo be done , I just wanted a but off help with it ,as I'm not used to using vcds, thanks,
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Bleed it manually - you'll have no probs
  7. HOTTIGGER
    HOTTIGGER Member
    99
    have u read the thread m8? i carnt bleed manualy, 1 of the nipples is broke off the m/c. thanks
  8. hades-
    9,482
    646
    bleed it manually its easy.
  9. Broken Byzan
    13,237
    465
    What we are all trying to tell you, is using the VDCS method will have no difference in bleeding than doing it manually. If the nipple is broken, fix it. Then bleed however you like
