Vauxhall C20LET 2.0L CalibraTurbo injectors
A3 NICK Nov 7, 2013
  1. A3 NICK
    A3 NICK BOOOOOOOOOST!!!
    52
    Hi All, Just have a quick question about some injectors i have got. I have got a set of 349cc Vauxhall C20LET 2.0L CalibraTurbo injectors (Yellow) When i called up Rtech these are the ones they told me to get for stage 2 on my KO3s. Now will these just be a direct replacment or will i need adapters for them to fit? And would it be worthwhile upgrading my fuel pump as well?
    Thanks! (Included a picture of them just to make sure they are correct)
  2. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    They look like the ones I have. Might be worth picking up a new set of o-rings and if you have access to an ultra sonic bath/cleaner always worth doing while it's out.
    You got a vr6 maf housing?
  3. A3 NICK
    52
    Cheers Jay A3 so they will just fit straight in? ok will pick a new set of O rings up from vauxhall. I dont know anyone with an ultra sonic cleaner, anyone you can recommend? I have a 3inch Aluminium MAF housing but was told that it would not be needed.
  4. Jay A3
    2,130
    356
    Since your looking for yellow tops yours is an agu engine?
    For stage 2 I could stay with the standard injectors and maf but would only see around 220bhp as these components would max out. Rtech said change the maf and injectors and I would see more which I did.
    Amazon or eBay sell these cleaners for £15-£30
  5. A3 NICK
    52
    Yeah its an AGU, so i should stick the new MAF housing on as well as the injectors for the best results? I will have a look on ebay for some injector cleaning stuff. I would ideally like to see anything above 230bhp from the map, Hopefully i can achieve that.
  6. Jay A3
    2,130
    356
    Rtech said not to install the maf or injectors till your there so just collect the parts. If everything is running well with no faults you should a good figure. I'm at 240bhp with the oversize tip and BBT 10psi actuator. Did get to 260bhp on one run but niki didn't think it was safe running that hot.
    What spec you got?
  7. A3 NICK
    52
    Nice figures! Stage 1 i made 190bhp and 235Ftlbs with a milltek catback, K&N Filter and forge 008p dv on a KO3. I now have:
    3inch downpipe with decat
    Custom longlife exhaust
    Turborevs fmic
    VR6 clutch & G60 Flywheel
    KO3s
    Creation motosprts TIP, Will get an oversized TIP when i can.
    349cc Injectors
    3inch Maf Housing
    Drilled and grooved Mtech Discs with EBC pads
    JOM coilovers to go on after the map along with my MOMO gtr Alloys.
  8. Jay A3
    2,130
    356
    Ah decent setup apart from the tip.
    Reason why I changed from CM tip to sfs one
    If you can I would change it before you go rtech...
  9. A3 NICK
    52
    It is a mahooosive difference!! How much did that set you back? Dont suppose you know anyone who has one laying around for sale on the cheap :whistle2:
  10. Jay A3
    2,130
    356
    Set me back about £160 direct from sfs. But if you speck to rtech I'm sure they have a batch at the moment for £100 a piece approx.
  11. A3 NICK
    52
    Awesome will have to ask when im up there! So you reckon with that set up i should see ok figures even with the sh***y TIP? Also changing the cambelt and water pump while im doing the turbo. Need to get hold of VAG COM before ideally as would like to see if its running any faults before i take the drive up to R-Tech!
  12. Jay A3
    2,130
    356
    If your car is in good condition with injectors and maf you should see the better side of 220bhp
  13. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    You'll get 230bhp from a GOOD AGU and K03s without ****ing about with injectors.
    Niki knows this.
