Valve Spring issues etc on 58 Plate Audi S3
controlz Mar 3, 2013
  1. controlz
    controlz Member
    54
    Hoping you guys can help. I'm on the verge of purchasing a November 2008 Audi S3, when I did some digging on the forum and read about the Valve Spring issues and similiar (TSB).
    It's got me quite concerned as I'll be purchasing the car without a warranty... Are there any mechanical / performance issues that could result in this if the car is affected?
    Furthermore, I'm planning to remap the car within 6 months and have read this can be an issue on a remap... I'm hoping to find out a little more, or if I can be sure the car is affected or not. It has FSH from Audi.
    Thanks!!
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi mate tbh its pot luck ,as i had a dec 58 facelift model running stage 2+ revo with no issues ,ran my car on stage 2+ on stock clutch for about a year ,but s3rye had a 58 plate facelift with this issue...
  3. NHN
    29,332
    1,716
    Is hardly been discussed on here tbh, I cant guarantee it wont happen, but its on the lower side it would.
  4. controlz
    controlz Member
    54
    Thanks Nigel, was hoping it would be quite rare. Is there anything within the engine-bay that I could look at when viewing the car that could perhaps be a hint the car may be affected?
    Also, is the car only affected when remapped... so in stock form the car would be fine?
  5. NHN
    29,332
    1,716
    I dont know of anything tbh, a good spirited drive would maybe show something, but like you say from what I've read, its mapped cars that have shown obvious issues.
    Look for obvious things like starting, clutch, slipping, check oil, coolant levels & quality etc.
  6. controlz
    controlz Member
    54
    Isn't there a Letter 'C' or 'D' on a Diverter Valve I'm meant to look for!? (based on what I've read)
  7. Kelza
    3,078
    604
    Revised d value ;)
  8. controlz
    controlz Member
    54
    So the revised D Valve is what I want or what I'm looking for? Where in the engine is it?
    Also, I thought it was springs!??
  9. controlz
    controlz Member
    54
    Anyone know which Valve is the affected one? D?
  10. Kelza
    3,078
    604
    D value is what u need ,g value is the one you may have...
  11. controlz
    controlz Member
    54
    Thank you, and if it is G Value, are there only issues after remap? (not when car is in stock form?)
  12. Kelza
    3,078
    604
  13. Kelza
    3,078
    604
    Hi mate its just that bit stronger to hold boost and the g value is more prone to splitting ...
  14. Kelza
    3,078
    604
  15. Kelza
    3,078
    604
    The diverter value is just at the front there ,with the 3 bolts...
  16. controlz
    controlz Member
    54
    Thanks so much. When was the Revised D released?
    So, on a November 2008 car, it's almost certainly going to have a G? And if not a G then..?
  17. Kelza
    3,078
    604
    It may have g or d as mine was a dec 58 plate with a g value...
  18. controlz
    controlz Member
    54
    Do you mean the original D Value? (which I presume is just as weak as G?)
  19. Kelza
    3,078
    604
    Hi there ,theres 2 diverter values G and D ...D beening the best choice ...
  20. controlz
    controlz Member
    54
    Standing in front of my engine and still struggling to find the diverter valve! (at least anything where I can see the product number and determine if it's D or G!)
  21. controlz
    controlz Member
    54
    Okay, just managed to somehow bend my head around the engine to just see the edge of the diverter valve, and it's definitely G! I should definitely have this replaced then?
