vaggy burger
johnyj Aug 30, 2007
  1. johnyj
    johnyj Member
    264
    can any one help locate this in the engine
    i run vag.com and it said i need one of these
    Barometric Pressure (Altitude) Sensor (F96)
    i have ordered it from the stealers but they couldnt tell me where it is
  2. enda1
    enda1 Member
    436
    I searched Elsawin and took a guess at your engine code being a 1.8T AEB.
    On this engine
    The altitude sender is located in the electronics box next to the Motronic control unit.
    The Motronic control unit is located in the large black box to the right of the battery as you look at the engine bay.
    If you post up up your engine code I'll see if it makes a difference to the location.
  3. johnyj
    johnyj Member
    264
    this is what it printed out
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 8D0 907 558 E
    Component: 1.8L R4/5VT MOTR HS D03
    Coding: 04001
    Shop #: WSC 06335
    1 Fault Found:
    00528 - Barometric Pressure (Altitude) Sensor (F96)
    06-10 - Signal too High - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    No fault code found.
    does this mean theres something wrong with the abs aswell?
  4. enda1
    enda1 Member
    436
    You've got a 1.8L motor so the location of the barometric sensor is as per my post.
    With the ABS it says "No fault code found" so no you don't have a problem. The info is just the type of ABS controller
  5. johnyj
    johnyj Member
    264
    nice one hope this sorts my problem out.
    used vag-com on mates g60 carrodo and all that came up was abs no error so im it means no probs with hes
    cheers
