  1. daver
    daver New Member
    29
    HI all,
    My A6 1998 Tdi Engine Code AFN, what version of VAGCOM software do I need and also what kind of cable?
    Also where is the port located on the car please?
    thanks in Advance
    Dave
  2. maxlbrown
    maxlbrown Deep Blue
    248
    the port is under the cubby hole in the lower dash by the drivers door as far as leads go i got 1 from ebay and downloaded the software from vag com. Ver4.01 i think for USB.
    Max
  3. enda1
    enda1 Member
    436
    Daver.
    This is the response I got from Ross-Tech on the cables for my cars.
    "For use with both of your vehicles, any of our Interfaces plus a 2x2 adapter should work fine. The KEY-COM (if you have a 9-male-pin Serial
    Port) or the KEY-USB (if you only have a USB port) would be the most
    cost-effective:"
    http://www.ross-tech.com/vag-com/interfaces.html
    it all depends on your laptop. If you go to the link and email them they'll let you know
  4. nmb
    nmb New Member
    17
    if you have a serial port on your laptop, your cheapest and good bet is a simple KL serial cable. KKL cables will also work and they're more available now than KL. vagcom version 312 is more than adequate.
  5. daver
    daver New Member
    29
    thanks for all the replys guys will need to go look, my laptop has serial and usb :)
    rgds dave
  6. marmite
    marmite Counting the Tesco Club points
    1,101
    I got my lead from Alpha-bid on e-bay works really well
